Just remove the dizzy, remove the shaft, make sure cylinder 1 is a firing TDC (timing mark to 0 degs),refit dizzy shaft to conventional position.
Now spin the engine until the timing mark is pointing at the 8 degs mark and fit the dizzy.
Connect the dizzy to the coil, and a 12v bulb to the coil, switch the key to on as if engine is running.
Rotate the dizzy until the bulb light goes on, when the light is on you have the dizzy static timed to roughly 8° before TDC.
Secure the dizzy clamp.
Thats the first step, an 'initial position', once done you can further tune timing to max advance.
Edited by jaydee, 15 January 2014 - 09:31 PM.
