Not Going Past 50Mph Does Accelerator Need Adjusting Under Bonnet?
Posted 17 January 2014 - 09:36 AM
Posted 17 January 2014 - 09:39 AM
Posted 17 January 2014 - 09:42 AM
Is your foot flat to the floor at 50mph?
Posted 17 January 2014 - 09:51 AM
is your speedo accurate?
Posted 17 January 2014 - 09:56 AM
Has it got any oil in it?
Posted 17 January 2014 - 09:59 AM
Edit: ok, in all seriousness what someone said below regarding fitting a filter and not changing the needle is a good suggestion. Also as others said, check your getting full throttle.
Edited by jackmason, 17 January 2014 - 06:11 PM.
Posted 17 January 2014 - 10:23 AM
FS
Posted 17 January 2014 - 10:43 AM
Posted 17 January 2014 - 10:55 AM
go faster stripe and speed holes needed!
Posted 17 January 2014 - 11:41 AM
It's a possibility, though unlikely. You could get someone, or a brick, to hold the pedal down while you see if the throttle is turned fully by the pull of the cable.
The nearest equivalent cause is a clogged air filter, but there are masses of others from binding brakes to a clapped out engine.
Posted 17 January 2014 - 12:23 PM
hahaha some funny answeres here
Posted 17 January 2014 - 01:45 PM
If you have fitted a K&N style air filter, but not changed the carb needle, it will go all asthmatic at around 50 or so.
Posted 17 January 2014 - 03:46 PM
Yes but there shouldn't be. Please don't mess about in the technical section, this is someone asking for our help and judging from the question asked they have limited experience or technical knowledge. Please try to be helpful, or don't reply.
Posted 17 January 2014 - 05:32 PM
Have someone pushing the throttle down and see if you can pull the throttle any further down on the carb.
Could be wrong settings of the carb too. Bad oil, flat tyres, no ignition on 1 cylinder maybe?
Posted 17 January 2014 - 05:44 PM
does it run rough on idle? or when you do the throttle by hand at the carb?
