Hi,
The edge at the bottom of the window has some rust as you can see in the pictures. There is absolutely nothing wrong with the scuttle so do you think its best to just cut this out and weld a new thin strip in?
Thoughts?
Rod
Posted 18 January 2014 - 03:24 PM
Hi,
Thoughts?
Rod
Posted 18 January 2014 - 03:29 PM
I would have a look with a mirror inside the cavities at each end and also right underneath the scuttle. I say this as i have seen this before and there was a lot more rust underneath.
If it is clean underneath and at the end i would cut a section out and then weld in a new piece.
Posted 18 January 2014 - 03:51 PM
Cheers, Neil. It is clean underneath. So I shall start chopping out and replacing once I get a new Control board for my welder.
Rod
Posted 18 January 2014 - 06:27 PM
You may get away with a good dose of rust converter. I had similar on a Mini that'd lived at the seaside for several years, water was trapped under the rubbers, but doesn't make it to the inside. Phosphoric rust converter fixed it for the rest of the life of the car, including a few years without paint.
Posted 18 January 2014 - 06:40 PM
Removing rusty metal is always best but this is an area on the car that I would prefer not to weld on. I would do as Ethel said and treat the rust with phosphoric acid and a lot of wire brushing. Once that process has been completed, I would use body filler to level and smooth the surfaces followed by regular paint. If you don't like the idea of polyester body filler for those pits under the rubber seal, you could use metal filled epoxy instead. In the end it is obviously your choice.
Posted 19 January 2014 - 10:00 AM
sounds good. I was a bit worried about getting a good finish in this area. I'll give that a try.
Thanks,
Rod
Posted 19 January 2014 - 10:09 AM
I suppose what you are doing about paint could be the decider, if you are spending big money on a respray soon you may prefer not to risk it. If it can stand long enough to prove the rust has been beaten, or touching in isn't a problem you may be happy to try the converter. Deliberately causing surface rust so it can be converted to phosphorous salts is a pucka finishing process for steel products.
Posted 19 January 2014 - 12:09 PM
Posted 19 January 2014 - 04:36 PM
perhaps some further investigation is required then to be sure its ok.
Posted 19 January 2014 - 04:53 PM
Cut out a small section say six inches and have a look.
Posted 21 January 2014 - 10:20 PM
It's on my job list for tomorrow.
Rod
