Whats The Difference Between High And Low Compression Engines
3 replies to this topic
#1 Ministage2
Ministage2
    Experiment Failed
  • 61 posts
Posted 18 January 2014 - 10:45 PM
Hi Folks
In addition to my earlier posts about my stupidity regards my stage 2 head tuning issues.
Ive heard high and low compression engines mentioned.
The rolling road guy said something about high and low compression engines???
whats he on about?
#2 miniman24
miniman24
  • 1,696 posts
Posted 18 January 2014 - 11:04 PM
High compression engines have higher compression :D Not sure about large bore engines but with 998's its to do with the dish in the piston - earlier engines had dished pistons (about 6cc dish I think) which lowered the compression compared to the later flat top pistons.
#3 jakejakejake1
jakejakejake1
  • 644 posts
Posted 18 January 2014 - 11:16 PM
They are referring to the compression ratio of the engine, generally the higher the compression ratio the better as it will be more powerful if nothing else changes. But there are limits to how high you can go.
As mentioned some engine had dished pistons which reduced the compression ratio, or flat top pistons which had a higher compression ratio.
#4 Stu1961
Stu1961
  • 636 posts
  • Local Club: Still Looking
Posted 19 January 2014 - 02:12 AM
Any number of things can be done to change the compression ratio, usually people are looking to increase it. I think it's basically the cubic capacity of one cylinder divided by the volume of the space above the piston when it is at top dead centre.
