do refurbishes paint, powder coat or re anodize them?
Posted 19 January 2014 - 10:49 PM
Posted 19 January 2014 - 10:52 PM
Depends on what you ask them to do bud?
Posted 19 January 2014 - 10:55 PM
i see, that pretty much answeres it,
Posted 19 January 2014 - 11:04 PM
unless they are forged they won't be anodised
That was easy!
Seriously though, any good refurbishers will be able to do any of the above, most popular seems to be a powder coat with a clear coat applied for gloss. Diamond cutting is also popular however requires a lot of maintenance to be kept looking good!
Posted 19 January 2014 - 11:30 PM
That was easy!
Powdercoat is glossy.....no need for clear coat.
Posted 19 January 2014 - 11:31 PM
i guess powder coating is probs the best value for money? i pretty good with a spray gun and good ol wet and dry but powder coating would be allot more durable
Posted 19 January 2014 - 11:32 PM
You say that but once powdercoat chips, water can easily get underneath it and it then peels/flakes off in big pieces. But for wheels, unless you hit them off the pavement, you will be fine :)
Posted 20 January 2014 - 01:16 AM
Posted 20 January 2014 - 09:58 AM
for a full 'refurb' if you paint wheels it doesn't matter how fantastic a painter you are it's a pain in the backside to do one side without getting overspray onto the other and that's when things start to get a bit messy!! the more complicated the shape of any spokes etc the harder it becomes.
i don't like powder coat on chassis/suspension arts etc as theses take a lot of stick and can easily get chipped leading to corrosion thus leading to water getting sucked under the coating. on wheels and other bits as long as you have a decent key on the surface, there is no left over previous coatings, it's primed well and you use a decent powder coaters then you shouldn't have a problem.
Posted 20 January 2014 - 10:12 AM
I have had lots of my alloys powder coated but at the same time I have painted lots as well. At least with paint it you do curb them then its easy to just re paint the damaged bit but with powder coat ones it gone and the water gets under neither all you can really do it shot blast and powder coat it again.
Same as the post above. All the suspension bits under my car I have just painted in stone chip paint. As a nice finish and its more hardwearing.
Posted 20 January 2014 - 01:48 PM
hmmmm, well the wheels are for my gf's mini and sheees well a bit more likely to catch a kerb :L as with me curbs are lava, lava is hot and to be avoided!, I’ll have a go at spraying them, ill be sure to post a pic in the paint section when ever they get done, she likely to want baby blue or something
Posted 20 January 2014 - 06:17 PM
i have sprayed quite a few sets of wheels, and if you are good at painting you wont have any trouble with overspray etc, paint the inside of the wheel first, then the back, then the front last.
im going to do my spare set of alloys for the metro in a month or so and get them on for the summer this year, if you do them a metallic colour, like silver as most alloys are, then 2k clear top coat they should last quite well, 2k laquer is quite tuff really, certainly compared to celulose
