hay everyone i have a 1275 with hif44 carb in my mayfair and she does not idle well its sitting between 1000 and 1500 rpm but does not sit steady iv tryed the timing off the dizzy but its still fluctuating up and down and i now have a flat spot has anyone had the same problem and how did you fix it or is there something up with my carb thats making it do this any help would be great
1275 Idle Problem
Posted 20 January 2014 - 02:48 PM
Posted 20 January 2014 - 03:49 PM
iv just been out in it there and she has no flat spot now and the idle has come down to between 900 and 1100 but still wont sit steady anyone any idea why shes fluctuating like this
Posted 20 January 2014 - 03:52 PM
possible air leak somewhere. Between carb & manifold and/or manifold & block is a usual suspect
Posted 20 January 2014 - 04:24 PM
and will that cause it to hunt like that iv just had it on the ramp and the v piece is blowing at bit so il tink il check all seals around the mani and carb tomoro
Posted 20 January 2014 - 07:29 PM
Air leak, check manifold nuts, breather pipes and the big servo vacuum hose, maybe the joint on the manifold is loose and leaks.
Posted 20 January 2014 - 07:56 PM
Posted 20 January 2014 - 09:45 PM
BDL needle is a standard needle for a MG Metro, has the problem just started or been there for a while? air leak or incorrect mixture setting is where I'd be checking and wear in the spindle allowing air in and a inconsistent idle
Posted 20 January 2014 - 10:20 PM
Posted 20 January 2014 - 10:31 PM
Catch hold of the linkage on the side and feel for movement, where the cable pulls the cam open against the spring
Posted 20 January 2014 - 10:42 PM
Posted 20 January 2014 - 11:06 PM
Some of the cheaper manifolds are not made of the correct thickness material on the flanges so they are usually fitted using stepped washers to enable to centre bolt to pinch up the flange to gasket correctly and prevent leaks,
Posted 20 January 2014 - 11:24 PM
Posted 21 January 2014 - 12:12 AM
Yeah but this one is the same thickness but wit the extra lumps of metal it doesn't sit right at all and the washers don't sit flat they sit at an angle so if i grind it down it shud make sit right so i can get them good an tight against the block
Ah I see that should sort it
Posted 21 January 2014 - 08:37 AM
cheers for the help mate il let you know how i get on when im finished
Posted 21 January 2014 - 06:49 PM
