Well, the head gasket broke about 6mm between cylinders 3 and 4, I've got the cylinder head off, got my feeler gauges but I can't find anything about any tolerances in gap-age. If anyone understands? Haha.
Head Gasket
Posted 20 January 2014 - 06:05 PM
Posted 20 January 2014 - 06:13 PM
Posted 20 January 2014 - 06:20 PM
Sorry, can't explain myself very well... Measuring the distortion, if the head or block has warped.
Posted 20 January 2014 - 06:55 PM
Posted 20 January 2014 - 07:18 PM
As above these heads wont warp 99% of the times, usually a good clean is enough.
A light skim is reccomendable if the surface looks 'worn' and will help for a better seal.
Lap the valves in while you're at.
The use of a quality head gasket instead of the cheapo cooper faced thats what actually makes a difference.
Edited by jaydee, 20 January 2014 - 07:19 PM.
Posted 20 January 2014 - 07:21 PM
Posted 20 January 2014 - 07:30 PM
You also cannot really measure head/block warping with feeler gauges. Best bet it a machine shop or even a steel rule and a light can work. But as above, rarely warp.
Ahh, fair play. Got the rule too but I was going with what my mate who works at Volkswagen said haha.
Thank you guys, appreciate the advice. The cylinder head will go back on this weekend then.
Posted 20 January 2014 - 07:39 PM
Dan
Posted 20 January 2014 - 09:07 PM
That is exactly what I do as well. Works fine. It is very, very rare for a cast A-Series head to warp and it would have to be seriously overheated to do so. By seriously, I mean the engine would have seized with the heat.
Posted 21 January 2014 - 01:11 PM
That would be impressive haha. I changed my radiator a few months ago, as well as hoses, clips, etc... Can't think of what would have caused the break though as the engine wasn't running that warm. I went over a bump? Haha.
Posted 21 January 2014 - 04:51 PM
They don't warp but they can erode, if they've been blowing steam through a failed gasket for long enough. Stick a good flat edge over where the gasket failed & look for light coming through the gap, or rather a lack of both.
