Bite Point
danny
, Jan 21 2014 08:24 PM
7 replies to this topic
Posted 21 January 2014 - 08:24 PM
Hi im in the process of reassembling a 1985 mini and just started it up for the first time and I've noticed it has a really high bite point virtually at the top of the clutch travel does this mean a replacement clutch or could it be something else :)
Posted 21 January 2014 - 08:40 PM
Have you bled the system ? Is it verto or pre-verto set up ?
Posted 21 January 2014 - 08:42 PM
I've not bled the system yet I need to bleed the brakes so probably worth doing at the same time. I'm not 100% sure on the style of the clutch is there an easy way to tell without taking it apart :) and thanks for your answer
Posted 21 January 2014 - 09:04 PM
How long is the clutch arm (roughly)? A picture of the clutch wok/arm/slave cylinder would help
Posted 21 January 2014 - 09:29 PM
Thanks just been to the garage and it looks short not sure if you can see on this pic
Posted 21 January 2014 - 10:09 PM
Yeah thats a verto clutch, if/when it's bled properly, if it's still biting high the chances are it's the clutch plate thats worn
Posted 21 January 2014 - 10:57 PM
Thanks I'll bleed the brakes and clutch at the weekend if not will I need this http://www.minispare...px|Back to shop or this http://www.minispare...AF.aspx|Back to thanks again for all your help
