New Clutch Needed, Which Is Best?
8 replies to this topic
#1 29guitarman
29guitarman
  • 60 posts
  • Local Club: FABMOC
Posted 22 January 2014 - 11:12 AM
Okay, so i have a Pre verto clutch in my 998, with a stage 1.
oh and  i have searched for the subject but couldnt find what i wanted.
Just got it all set up, running the best it ever has with power i didnt know it had!
but for the past few months it had been slipping slightly, now the engine is running better its slipping a lot more, so it needs sorting.
Looking it some of the clutch plates available, i would like one slightly better than a standard one just incase i carry on modding the engine.
I have seen a turbo clutch plate, may seem silly putting one of them on it but though if its possible why not?
So my question is, which clutch plates are best? can i put a performance one on a standard pre verto clutch?
Thanks, Jamie
#2 Simon@minispares.com
    Minispares
  • Minispares
  • 3,247 posts
  • Name: Simon Jackson
Posted 22 January 2014 - 12:06 PM
The std Mini clutch plate is what they put in the Turbo's anyway. For 95% of 998's, the standard kit (which also fits the 1275's) will be more than up to the job, see our number GCK100AF
#3 MrBounce
MrBounce
  • 2,685 posts
Posted 22 January 2014 - 12:47 PM
Agree with Simon - I had the same standard clutch plate in a 1301cc Mayfair which had 79bhp and similar torque. Never had any issues with it.
#4 29guitarman
29guitarman
  • 60 posts
Posted 22 January 2014 - 01:10 PM
great, thanks, i will be purchasing one of them very soon :)
Any advice on other parts to change whilst doing the job?
#5 29guitarman
29guitarman
  • 60 posts
Posted 22 January 2014 - 01:16 PM
note that my gears are nearly always difficult to change down, grinding when going into reverse every time, always topped with oil, any solutions? clutch in general maybe?
#6 A-Cell
A-Cell
  • 1,610 posts
Posted 22 January 2014 - 01:21 PM
Check the primary gear oil seal for leaks. Could be oil on friction plate causing slipping. Also set up the 2 adjustments correctly on re-assembly.
#7 29guitarman
29guitarman
  • 60 posts
Posted 22 January 2014 - 01:25 PM
if its slipping and struggling to change down, is it more likely to be oil leak? or new clutch needed?
#8 A-Cell
A-Cell
  • 1,610 posts
Posted 22 January 2014 - 02:19 PM
If there is oil leaking then you will need a new friction plate. Also some brake cleaner to remove the oil from the other metal surfaces etc
#9 A-Cell
A-Cell
  • 1,610 posts
Posted 22 January 2014 - 02:21 PM
Difficulty in selecting gears could be due to poor set up, requiring adjustment. As it is slipping you need to get it apart to investigate. Put it right as you rebuild it. New seal, new friction plate, adjust it, maybe bleed hydraulics.
