What Damp Start Sprays Are The Best?
10 replies to this topic
#1 Poppet2
Poppet2
  • 135 posts
Posted 24 January 2014 - 04:29 PM
I want to start using one, how often do you use it and Is the best one WD40?
#2 Carlos W
Carlos W
  • 10,114 posts
Posted 24 January 2014 - 04:31 PM
Firstly, what are the symptoms you are trying to get rid of with damp start spray?
It may be that you need new leads, dizzy cap, rotor arm and points (if fitted)
#3 Poppet2
Poppet2
  • 135 posts
Posted 24 January 2014 - 04:47 PM
#4 Poppet2
Poppet2
  • 135 posts
Posted 24 January 2014 - 04:51 PM
I only use the car at weekend so it takes a while to start. There is a red light that flashes when
I take the radio face off, which I suppose drains the battery. All electrics renewed.
Edited by Poppet2, 24 January 2014 - 04:52 PM.
#5 Cooperman
  • 23,283 posts
Posted 24 January 2014 - 04:53 PM
WD40 is not an ignition sealer, it is a lubricant, albeit a very good one.
To really waterproof a Mini ignition first of all plaster the distributor cap, plug caps and coil end with a non-conductive grease or Vaseline. Then liberally spray the dizzy cap, plug leads & caps and coil connections with a proper Ignition Sealer spray. Don't use WD40 as it will thin the grease and cause it to come off.
If your plugs, caps, leads & coil are in good condition when you do this you will be able to drive through deep fords with no problems.
#6 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 24 January 2014 - 04:54 PM
I used to use one by silver Hook on my ancient 740 estate and it never failed to work, especially as the bloody thing would never start without it!
But that was towards the end when i didn't want to spend any money on it.
Like Carlos said, Might be worth looking into finding out if any repairs need doing rather than relying on a cold start spray. I used to hate getting soaked in the poring rain with the bonnet up, spraying everything up!
Good luck with it.
Ben
#7 Rog46
Rog46
  • 465 posts
  • Local Club: NSMOC
Posted 25 January 2014 - 03:00 PM
The red light you see when you hace taken the radio face off will be a LED which would take AGES to have any effect on your battery?
What are the symptoms you have when starting it? eg cranking very slowly, or cranking full speed but taking ages to fire, or something else!
#8 tiger99
tiger99
  • 8,584 posts
Posted 25 January 2014 - 03:13 PM
I always used Holts Damp Start, which forms a tough coating. Don't get it on your self!
#9 Poppet2
Poppet2
  • 135 posts
Posted 25 January 2014 - 06:55 PM
Cranking very slowly. I just put it down to the damp cold weather and the car only being used at weekends.
#10 Carlos W
Carlos W
  • 10,114 posts
Posted 25 January 2014 - 07:17 PM
It could be that the battery is on its way out, or that there is a current draw on it!
If its parked near a power source you could consider an optimate type product!
#11 Rog46
Rog46
  • 465 posts
  • Local Club: NSMOC
Posted 25 January 2014 - 08:06 PM
Cranking slowly is either a low battery, or a bad connection in the circuit. When you drive it at weekends does it crank normally after a run, or is it still slow?
How long do you drive it for at weekends? Is it long enough to FULLY recharge the battery? Does it have a generator or an alternator?
