Mk1 Brake Bleeding Problem
18 replies to this topic
#1 snowsports1
snowsports1
  • 68 posts
Posted 24 January 2014 - 07:37 PM
Hi I have installed a completely new brake system on my mk1 moke but I can't seem to bleed all the air out of the system. The front brake drums have two cylinders, could there be air not being bleed in one of the cylinders? As they don't both have bleed nipples?
#2 Gr4h4m
Gr4h4m
  • 1,802 posts
  • Local Club: Club less.....
Posted 24 January 2014 - 11:26 PM
I have used a clamp on the shoes with the drum off and an ezibleed to get all the air out before now
#3 snowsports1
snowsports1
  • 68 posts
Posted 28 January 2014 - 08:10 PM
Still having problems, now using eezibleed and have put 2 litres through with no air coming out, tried locking brakes off, when I did this I thought it was sorted but once I adjusted the brakes the pedal was spongy again
#4 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,168 posts
  • Name: Neil
Posted 28 January 2014 - 08:22 PM
Have you tried pumping the brakes while using the easibleed?? This has worked for me before to get rid of a stubborn airlock.
#5 snowsports1
snowsports1
  • 68 posts
Posted 28 January 2014 - 08:24 PM
Yes tried that! Also tried holding pedal down for 10 secs during ezzbleed
#6 cambiker71
cambiker71
  • 1,050 posts
  • Local Club: Cambscustomclassics.com
Posted 28 January 2014 - 08:33 PM
They're not adjusted properly then. If you had a hard pedal before readjusting the brakes then they're bled ok.
But, bear in mind that new brake shoes will feel slightly spongy with a longer than normal amount of pedal travel until they've been used and "run in"  ;D
#7 snowsports1
snowsports1
  • 68 posts
Posted 28 January 2014 - 08:41 PM
To adjust the brakes I locked them off them unlocked them until the started turning, it was only about quarter turn. At the moment the brakes aren't working without pumping the pedal, so it is more than a new pad issue
#8 Gr4h4m
Gr4h4m
  • 1,802 posts
Posted 28 January 2014 - 09:09 PM
The adjusters are square so you can only move them as one flat so 90deg
#9 snowsports1
snowsports1
  • 68 posts
Posted 28 January 2014 - 09:25 PM
Yes that's what I did quarter turn is 90 degrees
#10 cambiker71
cambiker71
  • 1,050 posts
Posted 28 January 2014 - 09:31 PM
What about the front ones?
#11 cambiker71
cambiker71
  • 1,050 posts
Posted 28 January 2014 - 09:33 PM
Should be adjusted so that they are just binding, and only just or they'll overheat, do each adjuster at a time on the fronts with them all initially locked up, freeing them off one at a time and checking the pedal each time.
#12 snowsports1
snowsports1
  • 68 posts
Posted 28 January 2014 - 09:34 PM
I didn't have to move them much to free them up probably less than quarter turn
#13 grumpy dad
grumpy dad
  • 305 posts
Posted 28 January 2014 - 09:35 PM
Hi
its possible that its the master cylinder
try this crimp the 3 flex hoses
G clamp or mole grips
try the brakes if its the master cylinder
you will have the same problem
if that is OK remove the crimps one at a time
try the brake each time
you will find the bad one
#14 cambiker71
cambiker71
  • 1,050 posts
Posted 28 January 2014 - 09:41 PM
That sounds about right but the front are more difficult as there's two adjusters, take your time and work on each wheel at a time like i wrote before.
To adjust the rears turn the adjusters in until the brake locks then work the handbrake and it'll free off a bit, do this until they are actually locked and you can't turn the drum any more. Then undo the adjuster one click (1/4 turn) at a time until the brake is free enough to turn with a small amount of resistance (binding slightly)
#15 Stu.
Stu.
  • 912 posts
Posted 28 January 2014 - 11:46 PM
The front shoe adjusters on my 850 roundnose have offset cams which don't need much turning to make a big adjustment. The rears are screw / out worm adjusters which need more turning for the same adjustment I find. Sounds like an adjustment issue rather than air lock to me. Hope you get sorted.
