hi there having some issues with my charging system, right i changed my battery and alternator about 2 mouthes ago at the same time but the other day my battery went dead i charged it and tested it with the multimeter iderling off load was around 12.7V and going up very slowly but not flucuating at all, once on load it just kills its goes strait down to 10V ? i got told to cut the thin brown and yellow wire at the back of the alternator and earthed it to see if the light yellow lit up as i got told it was my charging warning light but it didnt light up with igniton on or when running, but i did find that when i cut it the red one didnt light up at all so i fort the wiring is arse about face if that makes sence so fair ? but i carnt work out what is wrong with it now, do i need to add an extra earth lead to help it charge under load or do i need to take my alternator back to the shop and swap it ? but once ideling for so long the red light on the dash does light up but onced rev'd the red light will go off again ? any help would be great really confusing are wiring diagrams haha
thanks ben
