Engine Help Needed
3 replies to this topic
#1 Jammin70
Jammin70
  • 10 posts
Posted 25 January 2014 - 02:23 PM
Hello,
I have an '84 Mayfair 1000, that i have taken the engine out of due to the body having work done on it,
Having never taken an A series apart i don't know what it is supposed to look like,
The concerns i have are circled in red, It looks as if there are supposed to be holes there but are blocked up, I have looked on the bottom of the cylinder head and there are holes there as well as on the head gasket. Are there supposed to be holes or am is it fine?
The one circled in blue, i was just wondering whether it is supposed to be bigger?
Any help is very much appreciated.
#2 grumpy dad
grumpy dad
  • 305 posts
Posted 25 January 2014 - 04:08 PM
Hi
no you are fine with the holes
its is how it is meant to be
depending on how much work you are doing
it would be good to give the block a skim
just to take the crotision marks out
#3 Jammin70
Jammin70
  • 10 posts
Posted 25 January 2014 - 09:31 PM
Thanks grumpy dad, I am only replacing the gaskets
#4 grumpy dad
grumpy dad
  • 305 posts
Posted 26 January 2014 - 10:14 AM
Hi
is that rust i see on the block ?
if so wip the studs out and rub the block with wire wool
