60^s Cooper Identity?
Posted 25 January 2014 - 06:12 PM
Posted 25 January 2014 - 06:15 PM
Posted 25 January 2014 - 07:17 PM
Posted 25 January 2014 - 07:20 PM
Why would it be a mistake?
I am guessing because it isn't 997cc
Posted 25 January 2014 - 07:39 PM
Posted 25 January 2014 - 07:56 PM
Posted 25 January 2014 - 09:53 PM
Before buying any Cooper or Cooper 'S' you need to research what you should be checking as there are simply loads of replicas out there.
Even with that knowledge it is still easy to buy a replica, but at least you will be giving yourself a better-then-evens chance of getting a genuine one.
The engine was 997 up until he end of 1963, then they went to 998, although there were 997 cars still coming out of dealers in 1964. The 997 is a horrible engine, but the 998 did transform the car.
A 998 has bigger brake callipers than a 997, but the same size discs, 7" dia x 1/4" thick.
All 997 & 998 Coopers have a 3-dial centre dash binnacle with a 100 mph speedo (the 850 had a 90 mph speedo).
In he boot there should be a boot board supported over the spare wheel on boot board brackets.
There should be chrome rim over the tops of the doors.
The Morris & Austin have different grills from the 850's, and from each other.
The Coopers have twin HS2 carbs with a 3-into-1 fabricated manifold, although most will have had this item replaced by a tubular steel one by now.
Gear change should be a remote shifter in an aluminium alloy extension with the lever between the seats.
Inside the Cooper the top & bottom dash rails and right up the A-posts should be covered in black leather-cloth.
There are other minor things which a Cooper will have.
However, any replica will probably have all the above correct, so it is still 'buyer beware'.
