Leaving The Choke On
Posted 26 January 2014 - 11:10 AM
Posted 26 January 2014 - 11:18 AM
What year car and what size engine is it? If you need to leave the choke on all the time then you'll need to richen the mixture a tad then you won't need to leave the choke on all the time.
Of course it could just mean your carb isn't set up properly ...
Posted 26 January 2014 - 11:25 AM
I would suggest you either adjust your mixture to enrich it and see how that goes or you do a good service of the engine, checking plugs, points and fuel mixture along with your timing.
Out of curiosity has the car been MOT'd recently, the mixture could have been weakened off for it to pass its emissions.
Posted 26 January 2014 - 11:31 AM
Posted 26 January 2014 - 02:58 PM
You could have a leak on the inlet manifold in addition to everything else that's been mentioned. Spray wd40 round the inlet manifold gaskets with engine idling and if the rpm raises a touch momentarily it points to it sucking air where it shouldn't.
Posted 26 January 2014 - 03:36 PM
I'm with Alex here, for the car to run properly needing choke partially on means the carb needs adjusting or there is a timing issue as well.
But how can you change the oil mixture?
Also, how can they change it when it is being MOT'd, and not tell you about it?
Posted 26 January 2014 - 03:41 PM
Fuel/Air mixture, not oil mixture :)!
Posted 26 January 2014 - 03:43 PM
On carb engined minis there is a mixture screw which you can lean the engine off. A decent MOT garage can make an adjustment if its very close and then tell you. I lean mine off before it goes in but the age of my car (75) the emissions are not so relevant unlike newer mini's.
Just remember to tweak it back.
Posted 26 January 2014 - 04:15 PM
My 998 mini was set up on a rolling road including timing, fuel mixture etc and a full reprofile on the needle and cost me £84 and best money i have spent. Very reliable too!
My set up is;
998 (std bore) flat top pistons (high compression)
Maniflow freeflow manifold
alloy inlet manifold
hs4 carburettor
aau reprofiled needle
1.625" Maniflow single box exhaust right through to the tip
Cone air filter
Ignition timing is set to 12 degrees BTDC
Accuspark electronic ignition.
Also with this set up the emissions are within mot spec.
Posted 26 January 2014 - 06:58 PM
AC
Posted 27 January 2014 - 02:11 AM
Depends how much choke, the first 1/4" inch or so only speeds up the idle rpm. If you are using enough to get fuel enrichment - and that makes it run better, even when warm, then I'd start by checking your ignition. You may also have an air leak in the induction system. since the hif carb's choke is entirely separate to the main jet it could also be compensating for a fault with that.
