Show Cage Vs Real Cage
14 replies to this topic
#1 ozz1
ozz1
  • 141 posts
Posted 26 January 2014 - 11:20 AM
I'm quite tempted by a show cage I've seen...does 'show' cage simply mean it hasn't received FIA approval? Could I safely use the harness bar on a show cage- is it capable of withstanding loads generated by an impact? In the event of a roll-over scenario I would like it to have some structural value?
Thanks.
#2 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 26 January 2014 - 11:31 AM
No, a show cage is just for that - show. It most likely has no structural benefit and could even be more dangerous in a crash than not having one. It has been designed to look good not to keep you safe.
#3 vx220
vx220
  • 419 posts
Posted 26 January 2014 - 12:09 PM
The danger with ANY cage is the amount of extra possible contact points for your head in an accident!
It is surprising how much you can move even with a seatbelt. You don't want the cage near you unless you have a helmet on (track day etc)
This is why insurance goes up with a cage. Your passenger (or more likely their family) putting in a massive head injury claim...
All said and done, I love cars with cages! And fairly sure my next one will have one...
#4 ozz1
ozz1
  • 141 posts
Posted 26 January 2014 - 12:24 PM
Would you say it's inadvisable to use the harness bar on show cage? Cheers.
#5 sledgehammer
sledgehammer
  • 3,109 posts
slightly off subject - but I always wonder how many roll overs were caused by the extra weight
& the raising of the center of gravity & extra inertia
also a loss of performance on the road with the extra weight
make it out of balsa if you want looks  ;D
#6 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 26 January 2014 - 01:01 PM
It could be dangerous and potentially an MOT failure. Harnesses to be properly fixed to structural parts of the cars. The forces exerted through a small area in the event of a crash are enormous. Don't take risks with mounting them. I am only here because of a well mounted harness in my first mini. I was involved in a massive smash. An idiot overtook me as I was turning right. Had the harness come free I would have suffered horrendous and possibly fatal head injuries. Be careful.
#7 grumpy dad
grumpy dad
  • 305 posts
Posted 26 January 2014 - 03:23 PM
Hi
ERR NO its just dangerous and stupid
and people that know about cages will just take the pi!!
#8 Cooperman
  • 23,367 posts
Posted 26 January 2014 - 07:39 PM
It is really only sensible, as alluded to above, to fit a cage for proper motor-sport. They are not necessary on a road car and can be unsafe if not properly padded with the car having FIA approved seats & belts, plus wearing helmets when driving hard.
#9 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 27 January 2014 - 10:06 AM
Installing something that looks like a seatbelt but is so dangerously fitted that it won't offer any protection may also result in a criminal prosecution. It might fall under "Interfering With a Safety Belt Installation", big fines and mandatory jail time.
Edited by Dan, 27 January 2014 - 10:07 AM.
#10 cal844
cal844
  • 9,671 posts
  • Local Club: TFMOC
Posted 27 January 2014 - 11:27 AM
yup :)
#11 JustSteve
JustSteve
    Puke-Boy!!
  • 1,883 posts
Posted 27 January 2014 - 11:39 AM
People call any type of cage a "show-cage". At the end of the day, there's possitives and negatives to all goes of cage.
Personally I would rather have an accident in a mini with a rear cage and harnesses, but being FIA approved doesn't make it ideal. I would rather make a cage myself personally
#12 vx220
vx220
  • 419 posts
Posted 27 January 2014 - 01:14 PM
I think there is a lot to be said for this approach for a road car
I'm thinking rear cage, harness bar and maybe some kind of door bars?
Keep it tucked up close to the shell so away from your head...
#13 Cooperman
  • 23,367 posts
Posted 27 January 2014 - 04:10 PM
If fitting a cage, then go for an FIA Approved one. They will take the stresses of rolling in the best way possible, provide for 4-point harness mounting and be right for competition. That's the best you'll get.
The Safety Devices ones I always use in rally cars are super and they fit well too.
I never fit a roll cage in a road car as I feel it is unnecessary and it's extra weight as well. Plus they make the car a 2-seater.
#14 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 27 January 2014 - 04:14 PM
Having had the pleasure to see at first hand how safety devices go about designing and testing a cage I can say categorically that no one person could do this at home to the same standard. Even if you regularly work with the correct materials and are a fully qualified welder, that is only half the picture. The vast majority of work in a cage happens before any metal is cut. The load paths are studied with hundreds of hours going into making the cage do what it should. I have a safety devices full weld in cage sat at work ready for our project and it seems a lot of money for a few tubes, that is until you see what it takes to get there and suddenly it seems very good value indeed. And with regards to having an accident with/ without, that entirely depends on the accident and what the driver or passenger are wearing.
#15 grumpy dad
grumpy dad
  • 305 posts
Posted 27 January 2014 - 06:05 PM
Hi
MSA regs stipulate CDS in 45mm o/d 2.5mm thickness or 38mm o/d 3.0mm thickness IIRC. T45 can also be used. Roll cage manufacturers have big hydraulic tube benders to cope with such heavy material
I am fitting one of these
http://www.customcag...5&type=Historic
but you will want one of these
http://www.customcag...ll&type=Bolt in
