desperate for help as i wanted it sorted before its dark
Edited by RossKnight, 27 January 2014 - 01:33 PM.
Posted 27 January 2014 - 01:31 PM
Posted 27 January 2014 - 02:55 PM
It can't be anything to do with it being in gear as the clutch is nothing to do with the gearbox.
It must just be the arm stuck in the plunger. Pour some releasing oil in, or some diesel, to 'unstick' it. Then just pull it out.
Best thing might be to fit a new arm if there is excessive wear on the ball at the bottom.
Posted 27 January 2014 - 03:00 PM
I assumed the plunger would have been further in the housing, as the clutch is stuck open(?), I can roll the car around with the car in gear, meaning the ball can't lift out easy enough
I will definitely be replacing the clutch arm, pin and clevis pin, as soon as I manage to get the arm off.
I can lift the clutch arm up above where the clevis pin went through, but it doesn't seem to want to come out the ball end
Posted 27 January 2014 - 03:14 PM
You might need to lever the plunger away from the clutch by levering against the big net on the end of the plunger.
To free off the plunger without removing the 'wok' you should try some penetrating oil (not WD40, as that is not a pen. oil) down the clutch arm mounting slot, let it soak, add a load more, then when the arm is out you can slide it in & out to free it off. The lubricate it with a thin oil (like 3 in 1). The problem is caused due to it being a steel plunger in an aluminium alloy housing.
You might have to take the 'wok' off to free everything properly and that would be best really.
Posted 27 January 2014 - 03:23 PM
Terrible picture I know, but this is all that's really happening when trying to lift the clutch arm out of the plunger, you can see the clevis pin hole, is no longer aligned, and it seems to be using the ball end as a pivot point rather than just lifting out
I'll get some penetrating oil on it tomorrow, and hopefully the arm will then come out the plunger, really trying to avoid taking the wok off as I don't want to have to try and get the bottom bolts off jacking the engine up etc
Edited by RossKnight, 27 January 2014 - 03:52 PM.
Posted 27 January 2014 - 03:51 PM
I suspect that the clevis pin slot is what is holding the arm in. Put lots of pen. oil on it and be firm with moving it. I've had to knock one out with a mallet once (or twice!).
Posted 27 January 2014 - 03:53 PM
Sorry, completely forgot to upload the picture, it's up now haha.
Could it really be the pin slot? the clutch arm seems to be able to move up and down in it, as you can see the pin hole is not aligned, I just can't pull it out
Thanks for all your help by the way
Posted 27 January 2014 - 04:03 PM
It does look as though it's the arm stuck in the slot. At the bottom it's just a small steel ball-end sitting in a big tapered cup and I've never ever had an arm stick there.
Swing the operating arm out of the way and prise the arm out with a big screwdriver or a small pry-bar, after putting more lubricant down the slot.
Before fitting a new arm, or even re-fitting the same one, clean up the faces on each side of the slot with a fine file & some emory cloth, then grease it well.
One tip is to put the new clevis pin in from the lower, i.e. inside, facing outwards as this makes it easier to fit the washer and split pin.
Posted 27 January 2014 - 04:28 PM
It seems to me that there must be an accumulation of rust in the hole in the plunger into which the ball end of the lever engages, so Cooperman's suggestions should work, eventually. It may need a lot of wiggling, and "persuading". Maybe lots of one of the various rust removing chemicals would help, but check that they are safe on ali, or you will be needing a new "wok".
I would take the wok off, as suggested, and work in relative comfort on the bench, or wiggle and pull it will watching TV or whatever. It will eventually come out. Being able to get more angular movement on the lever, because the plunger travel is unrestricted, will help, so remove the throwout stop nuts and work it all as far as possible in both directions.
Posted 27 January 2014 - 04:39 PM
Hammer.
Posted 30 January 2014 - 01:44 PM
Posted 30 January 2014 - 05:45 PM
In a previous thread I was told this;
remove the clevis pin and the clutch arm then put a spanner on the lock nut and turn the whole lot round and round whilst spraying it in wd40. then refit and put the slave back on and work it whilst still spraying in wd40
Put a spanner on what lock not? What shaft am I supposed to be spinning? I can't get it to free
Posted 30 January 2014 - 07:58 PM
The end of the plunger is a threaded section. This carries the throw-out stop nut & lock nut. Make sure these are locked together and then use a spanner to turn the plunger in the clutch cover. With the arm removed it should rotate freely and should, eventually, run in & out very freely.
With the clutch cover removed, which is the best way to make sure it is OK, you can undo the throw-out nuts and remove the plunger with the thrust bearing on the inside end and clean it up, check the thrust bearing, clean out the cover so that re-fitting is easy, assemble the cover with plunger, thrust bearing, clevis pins and throw-out nuts (loosened for re-setting after final fitting.
When re-fitting the throw-out nuts must be undone a fair way, then adjusted AFTER the cover assembly is installed, the hydraulic system re-bled if necessary and, if pre-Verto, the clutch arm adjustment stop clearance correctly set and the clutch operation tested.
