http://www.minispare...21.aspx|Back to
if so are they any good or any better or worse than the proper mini heater
thanks
Edited by SA MINI, 27 January 2014 - 01:40 PM.
Posted 27 January 2014 - 01:38 PM
Posted 27 January 2014 - 03:12 PM
Interested..
Posted 27 January 2014 - 05:02 PM
I was looking into these the other day, they are made by a company called T7 design.
Heres a video on youtube from Mini mania about it
Posted 27 January 2014 - 06:11 PM
Posted 27 January 2014 - 07:53 PM
The problem with it is there is no fresh air being pulled if for de-misting..
Posted 27 January 2014 - 08:22 PM
That pipe out of the heater is sitting too high, it wont flow as it should and cause an airlock.
Posted 27 January 2014 - 09:04 PM
Do you mean in the minispares photo? As that isn't how its mounted in the car.
Posted 27 January 2014 - 09:22 PM
No mate, i mean in the minimania video, when they show the pipes in the engine bay
Posted 28 January 2014 - 02:18 AM
I'm looking at this mainly as a demister as well.
-The original heater pulls fresh air from?
-is the problem with the one in the video just the way is been set up or with the over all design?
Posted 28 January 2014 - 09:31 AM
More info and fitting options here: http://www.t7design....products_id=180
These are used in a good few rally cars where misting up is a problem.
Posted 28 January 2014 - 09:52 AM
Use one in my Metro, demists the screen fine with no fresh air feed.
Posted 28 January 2014 - 04:01 PM
Posted 30 January 2014 - 05:23 AM
I have one but not fitted it yet. I told a friend here in the USA about it last year and he fitted one... gives out a LOT of heat for a small unit. In fact he did the write up associated with MiniMania's video. Yes it's a recirculating heater, but I don't see why it couldn't be modified to pull air in from the original cold air intake (i.e. the hole in the right hand flitch panel).
Posted 30 January 2014 - 05:44 PM
