C16Xe Minus
23 replies to this topic
#1 TrialsLife
TrialsLife
  • 384 posts
  • Local Club: BAD MC
Posted 27 January 2014 - 04:45 PM
Copied from 16vminiforums, will update a little later
Its time I got my rear into gear and finish this, so it makes sense to start a project page!
I bought this early this year, from HARBER07 on here. Since then, aside from making a half finished exhaust manifold for it and taking the coilovers off, not a lot has gone on.
Here is a link to Harber's project page http://www.16vminicl...ead.php?t=29754
On the trailer home
Mocking up for the inlet manifold, hopefully be contacing BoggBrothers in the new year to get one made up.
Was not really happy with the angle the top arm was sitting at with the coilovers. Also, the coilovers were directly mounted to the fibreglass! Could have made this work, but have put dampers and rubber cones back in for now.
Things that I need to get sorted next are;
  • Driveshafts
  • Inlet Manifold
  • Exhaust Manifold
  • ECU
The thing I am most stuck with at the moment is the ECU. I'm just not sure what to go for.
I know people say to go for a ECU which a local rolling road prefers, but I have not really looked into which rolling road to use yet.
Although I have been looking between MegaSquirt and VEMS. Currently leaning towards VEMS but any advice is most welcome!
Will try and update this with some more pictures when I get some work done on it!
#2 domdee
domdee
    Formally known as dominicdee
  • 1,183 posts
Posted 27 January 2014 - 04:52 PM
love a good minus!
#3 TrialsLife
TrialsLife
  • 384 posts
Posted 27 January 2014 - 05:04 PM
Update;
I have got hold of a Megasquirt v2 from Phil at extraEFI. Started making up the loom so that's a start!
The ITB's have been sent off to BoggBrothers for the inlet manifold to be made up.
The drive shafts have also been sent off to be joinined/sleeved together.
Started making up an exhaust manifold using two A-series manifolds. Although I think I am going to buy a 4-2-1, 1.4 corsa manifold and modify that as it would work a lot better than this.
Almost finished modifying the drivers side door. Had a lot of trial and error with this as it is the first time I have worked with fibreglass. It is currently curing as we speak.
The passenger door skin is riveted on at the moment, so I plan to bond that to the frame just like the drivers side.
That is all there is for now, its taking its time as I work away during the week so only have a small amount of time on the weekend to work on it. I'll get there!
#4 jonny f
jonny f
  • 1,485 posts
  • Local Club: Boxhill Mini Club
Posted 01 February 2014 - 05:09 PM
Yay a project thread!
Looks good so far.
#5 benjy_18
benjy_18
  • 1,038 posts
  • Local Club: LSMOC
Posted 01 February 2014 - 06:13 PM
Where are your door skins from? I'm after a decent set of composite skins
#6 classicspeed
classicspeed
  • 11 posts
Posted 01 February 2014 - 10:08 PM
hi ,heres my minus rear engined 1969 20xe
#7 TrialsLife
TrialsLife
  • 384 posts
Posted 04 February 2014 - 12:28 PM
The doors came with the car when I bought it, so I'm not really sure where they came from.
Looking good classicspeed!
#8 giacomo
giacomo
  • 684 posts
Posted 04 February 2014 - 04:46 PM
i wish i had the money for this when it came up for sale! i'll be following this very closely buddy :P
#9 1293gt
1293gt
  • 322 posts
  • Local Club: nonw
Posted 14 February 2014 - 11:52 AM
Love it!
#10 TrialsLife
TrialsLife
  • 384 posts
Posted 04 April 2014 - 10:07 PM
Quick update
Inlet manifold has been mounted on the engine with the ITBs
Megasquirt is wired up, except for the air temp sensor (on its way) and the wideband
Fuel pump is plumbed in and ready to go
This weekend I plan to,  get some flexi coolant hose tomorrow, connect all that up. Then weld the exhaust manifold up, then finish the megasquirt wiring. With the aim to start the engine Sunday afternoon/night.
With a bit of luck it will be turning over soon!
#11 Rocket.
Rocket.
  • 1,441 posts
Posted 04 April 2014 - 10:15 PM
Nice project ! Wouldn't mind a minus one day
#12 bluemini1979
bluemini1979
  • 619 posts
  • Local Club: Colchester Mini Club
Posted 05 April 2014 - 05:56 PM
Any pictures of the ITBs and manifold? Whats throttle bodies did you use?
#13 TrialsLife
TrialsLife
  • 384 posts
Posted 05 April 2014 - 09:51 PM
Will get some pictures tomorrow. I used CBR929 itbs
#14 Retrominisprint
Retrominisprint
    Previously known as madmodz
  • 91 posts
Posted 16 April 2014 - 03:56 PM
Hi, sorry to be a pain buy im hoping you can help me out?
Ive got a GRP mini, but a sprint rather than a minus, which also has a body chop... However im struggling for engine choice at the mo! Do you have any pics of the sump vs floor clearance, and any measurements with regards to the engine height? Also are you running 10s?
#15 TrialsLife
TrialsLife
  • 384 posts
Posted 16 April 2014 - 10:24 PM
I will try and get some pictures up tomorrow, as I promised someone else last week! Just never got round to that one.
The engine is a tight fit, but it is not too bad. At the moment the car is not sitting as low as it should be, I need to modify the knuckle joints to get it to actually sit as it should! Still, some pictures should give you an idea.
