Intermittent Wipe?
Posted 27 January 2014 - 07:11 PM
Also is it meant to wipe when you use the screen wash? As currently I have to squirt the washers and then put it onto first wipe.
I assume I have some electrical gremlins to conquer but I thought I'd ask in case I'm looking for a fault which doesn't exist.
Cheers all.
Posted 27 January 2014 - 07:14 PM
And I'm fairly sure it should squirt the screen wash and wipe if you have an ekectric screen wash pump.
Posted 27 January 2014 - 07:22 PM
Like above it should do a single wipe, I'm fairly sure it doesn't wipe automatically when you squirt the washer fluid (mine doesn't anyway).
Posted 27 January 2014 - 07:24 PM
Posted 27 January 2014 - 07:26 PM
Posted 27 January 2014 - 07:30 PM
Posted 27 January 2014 - 07:32 PM
Posted 27 January 2014 - 08:09 PM
They don't wipe when you wash.
Check the condidtion of your wiper blades - if they are worn the friction between the blade and the screen can increase to the point that it won't move on a dry screen.
Posted 27 January 2014 - 08:30 PM
Posted 27 January 2014 - 09:12 PM
So while you are washing they stop working ?
Operating the washer pump has no connection at all to the wiper motor - squirting water will not make the wipers move.
Pressing down on the wiper stalk (or up on my estate) into the non-latched position should operate one cycle of the wipers (but not the washer pump), or keep going until you release it.
Posted 28 January 2014 - 09:24 PM
When I operate the washers, the washer jets operate but it does not wipe, but you say this is correct so that's fine.
When I put the wiper arm stalk down into the unlocked position nothing happens, so I guess I will have to dust off the test lamp and see what's happening.
Thanks for the info, much appreciated
Posted 28 January 2014 - 09:48 PM
I think its the park sensor in the motor that stops the single wipe, mine used to work but doesnt now, but my wipers wont auto park either,
I would look in that direction if I were you, I just get used to it to be honest (although its very nice when I get into my daily and it works ;) )
Posted 29 January 2014 - 10:39 AM
If they are still working and parking properly, I'd be looking for a continuity issue within the switch first.
Test lamp it is!
Posted 29 January 2014 - 11:37 AM
When you push it down it should wipe once, I know the indicator stalk has little connectors on for the headlights that wear so I added a bit of solder to mine to beef them back up a bit, not sure if it's the same for the wipers though as I've not had problems, but it may help
Posted 29 January 2014 - 12:07 PM
Before diving into your test gear, just check that the wiper stalk isn't touching the column shroud - mine moves sometimes (aftermarket non-mini stalks) and the stalk won't quite move far enough to make the switch.
