O Ring Valve Seal
6 replies to this topic
#1 Dusky
Dusky
  • 5,322 posts
Posted 27 January 2014 - 08:11 PM
http://www.minispare...34.aspx|Back to
Where do I fit this?
#2 Dusky
Dusky
  • 5,322 posts
Posted 27 January 2014 - 10:10 PM
I know it has something to do with valve :P
#3 grumpy dad
grumpy dad
  • 305 posts
Posted 27 January 2014 - 11:08 PM
Hi
it fits on the valve stem
and stops the oil going down the valve guide
but I would use these if you can
 http://www.minispare...px|Back to shop
#4 Dusky
Dusky
  • 5,322 posts
Posted 27 January 2014 - 11:12 PM
I blought a head gasket set and got 4 of those seals you suggested, and 8 of those rings with it..
grtz
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 28 January 2014 - 08:20 AM
A head set is a 'universal' kit for the A series engines... there are many types of valves which have been used over the years, some use different seals, like you will also have lots of different manifold gaskets for the carburettor...
In this case you obviously don't need to use this particular type of valve seal...2A879 as this is only for really early A series heads
Traditionally only 4 valve stem seals were used, one for each of the inlet valves, as this stopped oil leaking into the combustion chamber, oil leaking down the exhaust stem would be blown out with the exhaust. If you want to fit valve stem seals on the exhaust aswell then order 4 more.
Edited by Guess-Works.com, 28 January 2014 - 08:23 AM.
#6 Dusky
Dusky
  • 5,322 posts
Posted 29 January 2014 - 09:12 PM
Ill leave the old ones on the exhaust valves then..
Any chance I could fit these little rings?
#7 madaboutcherry
madaboutcherry
  • 539 posts
  • Local Club: no
Posted 30 January 2014 - 12:18 PM
just put them in the bin, they're useless.
