Question:
Should I machine off the casting for the breather on the transfer case to make it look like a 3 synchro transfer case or leave it on.
Leave it on - keeps originality of parts
Take it off - a mk1 should not have a 4 synchro box or transfer case and 3 synchro cases never had the casting for the breather
Some additional information to read before you decide....
I have a 1967 mk1 cooper s REPLICA.
I wanted a cooper s but could not find one when I was looking regardless of price so when offered a mk1 super deluxe for free, I took it and started replicating.
The car is built to standard cooper s spec with the exception of a few st/comp bits like hilos, neg arms, tie rods, 4.5J minilifes etc. I also converted the car to dry for reliability.
The car came with a 998 which I cleaned up and put back in as I hoped to finish it in time for my wedding but failed, so now the wedding is done and bank balance has recovered I decided to build up the 1275 s engine I had for it. Decided to put an 1128 s box in it which is the correct spec for a late mk2 & 3. It also has the 940 1805 head like late mk2 and mk3.
So bearing in mind a mk1 should only have a 3 synchro box and transfer case, should I make my 4 synchro transfer case (22g1021) look more like a 3 synchro one?
Can easily machine it off if required.
Thanks Dave
Picture done just after the mot with the 998 in
