Fast Indicators
13 replies to this topic
#1 imaparana
imaparana
  • 580 posts
Posted 28 January 2014 - 09:26 PM
Hi There, after just sorted out my slow/weak indicators, they are now fast,
i know this is because ive removed the side repeaters from my car and putting a bulb in sorts this out however i dont wish to have side repeaters, am i able to add a resistor to sort this, if so what resistance ? or any other way ?
cheers
#2 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 28 January 2014 - 09:32 PM
Are all the bulbs ok? If one bulb blows it causes the other to flash quickly.
#3 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 28 January 2014 - 09:37 PM
I think the only UK Mini you can legally remove the side repeaters from is an 1100 Special. From 1985 all cars had to have them and it is an MOT item.
#4 coopdog
coopdog
  • 4,506 posts
Posted 28 January 2014 - 10:14 PM
Just hang the bulbs in side the wing instead
Job done :L
#5 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 28 January 2014 - 10:52 PM
This is what the testers manual says
Vehicles first used on or after 1 April 1986 must be fitted with one side repeater indicator on each side.   Instead of a separate lamp, the side repeater might be part of the front direction indicator if it includes a wraparound lens.
#6 planejob
planejob
  • 37 posts
Posted 29 January 2014 - 01:23 AM
Yes, you can put a resistor in.   Use a 25W, 3.5 ohm resistor in each circuit (left and right), wired in series with on of the existing bulbs would be fine or shove into the socket of the bulb you are wanting to eliminate.   It will calm your flash rate right down.
Edited by planejob, 29 January 2014 - 01:26 AM.
#7 Ethel
  • 26,580 posts
Posted 29 January 2014 - 02:01 AM
Or simply change the flasher unit to gfu2124
#8 stealth05
stealth05
  • 626 posts
Posted 29 January 2014 - 05:33 AM
buy a new flasher relay , the one you will have will be rated at 2x21w+5w you just want 2x21w relay it is seeing the 5w resistance missing so flashing fast .
Edited by stealth05, 29 January 2014 - 05:41 AM.
#9 maccers
maccers
  • 1,880 posts
  • Local Club: LSMOC
Posted 29 January 2014 - 07:05 AM
When I installed my new loom last year it came with connectors for side repeatrers and I dont have any, so I cut the wires, joined them and used a 2 * 21w relay as above, works fine. I have seen some people use an electronic one from a Fiesta which solves a lot of the problems associated with the physical metal relay types.
#10 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 29 January 2014 - 11:02 AM
Cut the wires and joined them? Can you clarify exactly what you mean please as that could be quite dangerous advice if taken wrong.
#11 maccers
maccers
  • 1,880 posts
  • Local Club: LSMOC
Posted 29 January 2014 - 01:29 PM
Yep, so where the wires go into the plug for the side repeater, cut that off, and joined the wires to complete the circuit. Seems to work fine for the past year ish. Is it incorrect?
#12 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 29 January 2014 - 04:31 PM
You joined the two wires at the bulb holder? If you mean the green is now connected to the black that's very wrong, you've created a dead short. If this were a constantly powered circuit there could well have been a fire so it's a good thing it's on the indicators as they are intermittent. If you want to do away with them just pull the bulb and tape or preferably heat shrink the holder to insulate it, then securely tape the leads back in a loop so they can't fall down. And as above swap the flasher unit.
#13 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 29 January 2014 - 05:57 PM
Thats assuming any mods done are on a car before the MOT regulation say the vehicle must have side repeaters, the OP will come back with the registered age of the vehicle, and then its either a mod or refit the repeaters
#14 maccers
maccers
  • 1,880 posts
  • Local Club: LSMOC
Posted 29 January 2014 - 06:22 PM
Just checked it now as its been a while! On the driver side I joined the green/white wires and left the black cut and taped back, and on the passenger the same, so green/red joined and then cut the black and taped back.
I recall when I was doing this the front indicators did not work, but I had forgot to join the wires after I cut the blub holder off. I dont know why I did not just tape them back now, must have been a reason, maybe too much cable to tie back!
