Clutch Arms
3 replies to this topic
#1 Jacks
Jacks
  • 102 posts
Posted 28 January 2014 - 10:27 PM
On a mini are all the clutch arm assemblies interchangeable because i have an engine just wondering if i get a different clutch arm set up will it be an easy swap.
#2 Jacks
Jacks
  • 102 posts
Posted 28 January 2014 - 10:28 PM
For example can i just swap the left arm over with the one on the right or will i have to swap the full cover over
#3 A-Cell
A-Cell
  • 1,610 posts
Posted 28 January 2014 - 10:39 PM
The left hand (short arm) is for the Verto clutch fitted from c1982, the RH one is an earlier one. Each one has to be fitted with the appropriate, corresponding internal clutch and flywheel assembly.
#4 tiger99
tiger99
  • 8,584 posts
Posted 29 January 2014 - 06:55 AM
I agree, and would add that even if you are not changing the clutch internals (plate and diaphragm spring), the cover (wok), operating plunger and release bearing differ between Verto and pre-Verto clutches, and the cover also differs according to whether you have an inertia or pre-engaged starter, and whether you need the timing hole, or have the timing marks on the crankshaft pulley at the other end instead. Obviously if you don't need the timing hole, you can still use a cover which has it, as long as you fit the cover plate. See here:
http://www.somerford...age=page&id=144
