Ignition Switch Location
4 replies to this topic
#1 newenglandmini
newenglandmini
  • 646 posts
Posted 28 January 2014 - 11:19 PM
My '74 Mini has an ignition switch steering column lock feature.  The ignition key hangs up in the lock cylinder, and it is difficult to remove.  I have tried to lubricate the mechanism with silicone spray without success.  Minispares doesn't appear to offer a replacement part.  I am considering simply replacing it with a old style dash-mounted ignition switch (Mk1, Mk2, early Mk3).  Would someone kindly post a picture of the old style switch location for my reference?
Thanks.
Attached File  DSCN4891.JPG   70K   9 downloads
Edited by newenglandmini, 28 January 2014 - 11:19 PM.
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 28 January 2014 - 11:34 PM
The wiring on the switch is different and its located centre of the switch panel on the earlier cars, Minispares list a Ignition Switch for cars though from 76- which I'm sure could be adapted http://www.minispare...|Back to search
But fitting it would require cowling mods
But SomefordMini list one item 83 here https://www.somerfor...age=page&id=86
But clicking on buy says obsolete
looks like ebay ? or a modification
Edited by KernowCooper, 28 January 2014 - 11:42 PM.
#3 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 29 January 2014 - 12:49 AM
Did the later Canadian cars not have seatbelt / ignition interlocks? Could it be something to do with that holding the key in place? Silicone spray will gum up a lock, and may also trickle down and short the switch. Locks should be dry lubricated with graphite powder or maybe a modern dry PTFE spray, give this a go first.
#4 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 29 January 2014 - 01:10 AM
I found the picture below online (not my car) it shows the ignition switch in the middle of the switch panel.
#5 newenglandmini
newenglandmini
  • 646 posts
Posted 29 January 2014 - 05:26 PM
Thanks to all.
