Window Washers Barely Work
7 replies to this topic
#1 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 31 January 2014 - 06:58 PM
The window washers on my mini are barely spraying any water. I checked and unblocked all the lines, and the pump seems to be in working order. I was wondering if the issue could be solved by installing a bigger pump or if there is another problem.
#2 L400RAS
L400RAS
  • 2,479 posts
  • Local Club: Lincolnshire Mini Owners Club
Posted 31 January 2014 - 07:01 PM
my guess is blocked jets.  either shove a pin in them, or remove them from the scuttle and proggle out the muck.
#3 grumpy dad
grumpy dad
  • 305 posts
Posted 31 January 2014 - 09:18 PM
Hi
check the one way valve in the line
#4 humph
humph
    How bad can it Be?
  • 1,107 posts
Posted 01 February 2014 - 09:58 PM
As per post 3 check the none return valve on the line, location will vary dependent on age and model.  Remove it from the line and blow through it in both directions, air should pass through it in one direction only.  I have also had a problem recently where I was getting very little fluid, barely a dribble from the chrome washer someone fitted to mine, turns out that the holes were too big an there was no pressure build up to form a jet, just a dribble.  Swapped them for a standard black set and problem was solved, good as new.
#5 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 01 February 2014 - 10:05 PM
If the jets are blocked then its worth whipping them out and sticking them in vinegar overnight. They come out as good as new.
#6 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 02 February 2014 - 05:19 PM
Thanks for all the advice, will give it a try in the next few days and let you know what the results.
#7 tiger99
tiger99
  • 8,584 posts
Posted 02 February 2014 - 07:51 PM
Talking of vinegar, use it on a cloth to clean your wiper blades. When my daily driver went in for a service, the manager advised me to do that, and it worked, the wipers really did wipe properly again. 25,000 miles later they are still wiping. Like clogged washers, the problem was probably due to a thin deposit of lime scale, which vinegar will remove. The suggestion to use it on the washer nozzles has a solid scientific basis.
It may work in your cooling system too, but you will need a lot of it, and it will need to be well flushed out afterwards.
#8 minimender
minimender
  • 1,589 posts
  • Local Club: M.M.M.
Posted 02 February 2014 - 09:38 PM
Helps sometimes to wash the bottle out thoroughly and blow through the pipes as bits settle at the bottom of the washer bottle and stir up as you drive getting back in the pipes again.
