Fitting A Monza Cap?
9 replies to this topic
#1 Kieran_Cherrill
Kieran_Cherrill
  • 50 posts
Posted 31 January 2014 - 07:32 PM
hellooo, would anyone be able too explain too me how too fit the monza style fuel cap? i got it today but diddnt come with instructions or anything :(
i got this one...
http://www.minisport...nk-adapter.html
thanks guys :)
#2 james962
james962
  • 2,677 posts
Posted 31 January 2014 - 10:15 PM
It has a collar which you feed over the fuel tank neck and tighten the grub/allen screws.Then put on the cap, the seals will seal the cap to the neck. I believe with the Monza type you don't use the old filler cap....whereas the Aston type it attaches to the old cap rather than the filler neck.
#3 Kieran_Cherrill
Kieran_Cherrill
  • 50 posts
Posted 01 February 2014 - 12:30 AM
the one i have here dosnt have any grub screws on the collar, i heard i have too solder it?
#4 james962
james962
  • 2,677 posts
Posted 01 February 2014 - 11:08 PM
ah that's weird. Does the collar have any holes and therefore the grub screws are missing out of the set?
Might be worth giving Minisport a ring and enquire.
#5 MaxAndPaddy
MaxAndPaddy
    Spamela Anderson
  • 4,700 posts
  • Name: Elvis
Posted 01 February 2014 - 11:40 PM
Mine just shoved on, was sufficiently snug to stay in place, course wouldn't stop it being nicked easily. My Aston style one came with grubs.
#6 Burgerdale
Burgerdale
  • 151 posts
Posted 17 February 2014 - 01:19 PM
Mine was interference fit, had to warm the collar up to expand and then lock it on with a rubber mallet. The only problem was lining up the thread so it would tighten into the right position.
#7 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 19 February 2014 - 10:06 AM
This is the MiniSpares one - http://www.minispare...monza.aspx|Back to search
And the one from your link above states "Monza Chrome Petrol Cap including Tank Adapter" so I guess you need that brass collar sent to you thats fitted as above.
#8 splintercat
splintercat
  • 616 posts
Posted 01 March 2014 - 08:32 PM
as it says really........................I heated my brass collar up in water and then tapped it over the neck with a rubber maul
make sure you have enough filler tank neck protruding to do this........think it was 10mm ish      ie the depth of the brass adapter at least..    older minis have this protudence  but later minis are a little less I think
Edited by splintercat, 01 March 2014 - 08:33 PM.
#9 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 02 March 2014 - 06:53 PM
.....and do anything to the suspension that requires tank removal first...!
#10 Haynes
Haynes
  • 489 posts
Posted 13 November 2017 - 05:57 PM
Resurection of an old thread, but I was researching fitting a Monza cap. Nothing's ever simple is it!
Does anyone know if you can remove the tank with the brass ring in place? It looks like the diameter isn't huge, so might go through the hole in the body work? I know you need every mm when trying to manouver the neck and tank in place, so does this make it impossible?
