Here's some video clips of the steering play. Click to watch the videos...
Posted 01 June 2006 - 02:16 PM
Posted 01 June 2006 - 03:21 PM
Posted 01 June 2006 - 03:25 PM
by the way because u have sportspack alloys get a quick rack otherwise your tyers will rubb
Posted 01 June 2006 - 03:28 PM
Posted 01 June 2006 - 03:33 PM
Posted 01 June 2006 - 03:38 PM
Posted 01 June 2006 - 03:41 PM
Posted 01 June 2006 - 03:46 PM
Have you tried the pinch bolt that tightens the steering column to the rack down at the floor? that was loose on mine before and i had the same problem
Posted 01 June 2006 - 03:48 PM
Posted 01 June 2006 - 03:56 PM
And I believe Bimu's car is a sportspack anyway? In which case it would be fitted with a sportspack steering rack, which Minis84 correctly states is not the same as a quickrack (which is something I've explained many times!
Personally I'd take the steering column off the rack and check the condition of the splines on both parts.
Posted 01 June 2006 - 04:06 PM
Posted 01 June 2006 - 04:18 PM
sorry! me being misinformed!
but still i think its the teeth on the rack give that a look.
sorry if i gave out the wrong info, i didnt mean to, was a mistake
appoligis to anyone who feels the need to say someing like
'DUR its not a quick rack its a sportspack rack you dumb ar*e'
but check the rack!
Posted 01 June 2006 - 05:05 PM
Posted 01 June 2006 - 05:13 PM
Posted 01 June 2006 - 05:38 PM
Yeah I noticed it wasn't a Sportspack rack but I don't think that will really change the feel of the steering, it's just heavy 'because they're big fat 13" wheels.
I remember you were worried about the steering when you came over. Nothing was loose then, it could be just a worn rack due to heaving those big wheels about or it could have loosened up as Dave says. I seem to remember that your tower mounts could do with looking at but I didn't look at any others. Get someone to watch the rack as you turn the steering left and right with the car stationary and see if the rack moves on the toe board as the crack sound is made. I've had that happen before, it's not that major. I think the Nylon strips are still there, probably just needs tightening.
