Rayvern Hydraulics Suspension
No replies to this topic
#1 GINO R32
GINO R32
  • 177 posts
Posted 02 February 2014 - 12:06 PM
Hi all I never got round to fitting the suspension so its up for grabs
Complete pump with actuator solenoid etc
Mixing block/valves
Rear rams.
Drop/lift hydraulic speed adjuster union
Pump to mixer/valve block hydraulic line
To complete the kit you will need:
Front rams (rayvern hydraulics supply these)
Hydralic pipes (cheap on ebay)
Switch box (not supplied in kit from RV anyway but easy to make)
Battery deep cell type (not supplied by RV but readily available on ebay, cheaper to buy leisure batteries)
I have the most expensive parts and the rest you can get together for a couple hundred or so if you are clever.
Someone on ebay is selling just a pump for £250 so I know this is a bargain. The value of the above is prob £600-800 new.
im after £200 ovno
