I assume you have tried the voltage measurements I described earlier and you have not found any voltage on coil (+).
The ignition system is typically not fused so you will not find an issue there related to coil power. There are "standard" and "ballast" ignition systems as well as factory and aftermarket electronic ignitions. That means a few different wiring possibilities.
Standard ignition with points:
White wire to coil (+) coming from the ignition switch. (Switched power to coil)
White/Black wire between coil (-) and the distributor.
Ballast ignition with points:
White/Yellow wire on coil (+) coming from the starter solenoid.
Pink (pink/white or strange off-color pinkish white) on coil (+) coming from the ignition switch. (Switched power to coil)
White/Black between coil (-) and the distributor.
Aftermarket electronic ignition:
Leaving the distributor: Red and Black wires.
Black wire to coil (-)
Red wire: Standard ignition- to coil (+), Ballast ignition - typically to the fuse box.
In all cases there MAY be a second white/black wire on coil (-) going to a tachometer if fitted.
Others will have to post information on coil wire colors for the factory electronic ignition.
