New Clutch
6 replies to this topic
#1 coopdog
coopdog
  • 4,506 posts
Posted 02 February 2014 - 10:26 PM
I'm fitting a new new clutch plate and diaphragm soon,
I think I read somewhere when you fit an uprated version you have to counter sink some bolts to make it work?
Any idea guys?
#2 tiger99
tiger99
  • 8,584 posts
Posted 02 February 2014 - 11:17 PM
Not to my knowledge. At the other end of the engine, you do have to countersink a couple of bolts in the timing cover backplate, if you fit a duplex chain and gears. Perhaps you are thinking of that?
#3 coopdog
coopdog
  • 4,506 posts
Posted 03 February 2014 - 10:12 AM
Hmmmmmm
I'm sure I've seen something about it :/
People fitting then and then having trouble engaging the clutch because of these bolts
#4 Cooperman
  • 23,513 posts
Posted 03 February 2014 - 12:27 PM
No, a comp clutch is a straight replacement.
#5 coopdog
coopdog
  • 4,506 posts
Posted 03 February 2014 - 02:52 PM
I must be thinking of something else then
#6 tiger99
tiger99
  • 8,584 posts
Posted 03 February 2014 - 08:05 PM
Well, there is another thing that goes wrong, if the starter motor bolts get mixed up with the clutch slave cylinder bracket bolts, both 3/8" UNC, but different lengths. There are a number of cases here on the forum of engines mysteriously not turning as a result of doing that. Easily fixed, but with a modicum of care such things need not happen.
#7 Cooperman
  • 23,513 posts
Posted 03 February 2014 - 10:25 PM
Been there, done that :D .
