Mk1 Coil Spring Clutch
5 replies to this topic
#1 surfblue
surfblue
  • 1,827 posts
Posted 03 February 2014 - 07:12 AM
Just stripped my engine and box from my 1963 Mini Minor. I had bought a diaphragm clutch kit but now realize its the early coil spring type. >_<  Where can I get a kit to replace this clutch, assuming the diaphragm kit is unsuitable?
Thanks in advance.
#2 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 03 February 2014 - 07:36 AM
I don't think there is a conventional kit available. The springs are valve springs, and I think the driven plate is the same as for the diaphragm. I'm not certain about the release bearing.
#3 Cooperman
  • 23,359 posts
Posted 03 February 2014 - 12:25 PM
It must be over 40 years since I last worked on a coil-spring clutch, but from memory the diaphragm clutch is interchangeable. If it isn't, then you just need a flywheel for an early car, 1964 onwards I believe. I'm sure the thrust bearings are identical.
I seem to remember making a competition coil spring clutch for an early 997 Cooper using heavier than standard valve springs, or did I imagine that?
#4 surfblue
surfblue
  • 1,827 posts
Posted 03 February 2014 - 06:17 PM
According to Minispares the older type is NLA and suggest fitting a different flywheel.
Will any pre verto flywheel fit?, ie will a 998 flywheel fit 850 crankshaft (might be a 998 one somewhere about home)
Will the same clutch cover (bell housing) fit?, it is a different release bearing, diaphragm one is thicker than the existing one.
#5 Cooperman
  • 23,359 posts
Posted 03 February 2014 - 06:33 PM
The only cranks a later flywheel won't fit are the very early thin-tail 850 cranks with the oil-fed primary gear. Not many of those left now.
I think the release bearing is the same, but for a few quid I guess you would fit a new one anyway. The clutch covers are all interchangeable.
#6 surfblue
surfblue
  • 1,827 posts
Posted 01 March 2014 - 06:15 PM
Having got myself a diaphragm flywheel and as I went to fit it today I discovered that yes, I have one of the thin tail cranks! so it would seem Im sticking with the coil spring type. I'm not going to go to the bother of changing the crank!
