Routing Rear Brake Hard Line(S)
4 replies to this topic
#1 bikewiz
bikewiz
  • 321 posts
  • Local Club: NEMO
Posted 04 February 2014 - 01:27 AM
'92 saloon
So I found this post
http://www.theminifo...ne#entry2864896
I'm in the same predicament the rear line needs to be replaced where it goes under the subframe my plan was to splice a union into the front line and route it as installed or just pass it over the sub to the t union. Some say yes it's OK to pass it over,some say no. Over the sub is easy, under the sub not so much. I have a good flaring tool (SYKES-PICKAVANT 02700100) and copper/nickle line so the fabrication is easy. Can you get the old line out without destroying it so I can copy it?
Advice would be appreciated.
#2 Simont
Simont
  • 198 posts
  • Local Club: Thames Valley Mini Club
Posted 04 February 2014 - 01:40 AM
you can put it over the subframe, but i dont reccomend it, what i normally do, is remeber the pipe route, then remove the old pipe, and just bend a new pipe gently by hand straight onto the car, if your careful, i believe you can just get it over top,
Either that or splice the connection and sort it out properly if you ever had the rear subby off
ive never done this on a mini, but there are several other classics with similar problems,
Edited by Simont, 04 February 2014 - 01:43 AM.
#3 bikewiz
bikewiz
  • 321 posts
  • Local Club: NEMO
Posted 04 February 2014 - 02:34 AM
I think I try and get it over the sub without taking it off, I just rehung my exhaust the thought of taking it off to remove the sub isn't really what I want to do.
thanks for the advice.
#4 maccers
maccers
  • 1,880 posts
  • Local Club: LSMOC
Posted 04 February 2014 - 01:45 PM
I routed mine over the subframe and through the interior of the car about two years ago, using correct pipe, I check it while doing any work as I check most bits under the car and it seems fine. If I done it again I'd probably get a braided section made up.
#5 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 04 February 2014 - 02:20 PM
i put mine in front of the subframe, not in the standard position and i also P clipped it in place so it cant rattle
