Door Pocket Speakers
8 replies to this topic
#1 mr.x
mr.x
  • 165 posts
Posted 04 February 2014 - 07:52 PM
What is the general thought on installing door pocket speakers? I am replacing my entire audio system, both rear speakers, radio unit, and want to add two more speakers up front. I am also thinking about adding a small subwoofer/amp under the rear seat. I want to system to look like it was factory fit and not aftermarket.
I found door pocket speaker pods on ebay bolt-on-bits. Are they any good?
#2 mr.x
mr.x
  • 165 posts
Posted 10 February 2014 - 03:17 AM
Anyone have any comments?
#3 minimanclive
minimanclive
  • 1,108 posts
  • Local Club: LSMOC
Posted 10 February 2014 - 06:53 PM
My brother had the bolt on bits door pockets in his Mini. They take a larger size speaker than the Metro door pocket which only took a 4" speaker.
They're OK, but the sound is directed at your legs which isn't ideal.
#4 roberts
roberts
    Optimise Automotive
  • 3,295 posts
Posted 11 February 2014 - 05:44 PM
Good afternoon,
We always recommend keeping speakers off the front doors, two reasons:
- Weight, you don't really want to be adding weight to the Mini front doors.
- Positioning - as above, they fire the sound at your ankles.
We recommend hanging them from the bottom dash rails: LINK
Hope that helps.
Andy @ Optimise Automotive
#5 blueturbomini
blueturbomini
  • 290 posts
  • Local Club: LSMOC
Posted 11 February 2014 - 06:22 PM
If you build your own door pods you can set them at any angle you wish.
#6 mr.x
mr.x
  • 165 posts
Posted 18 March 2014 - 11:12 PM
Thanks for all of the replies! I cannot mount on lower dash rails as car has custom air con system. I want whatever I do to look factory fit.
What do I do?
Also for a sub? Under the rear seat? A bass tub free standing or something built in?
#7 InstantCustard
InstantCustard
  • 80 posts
  • Local Club: Surrey Hills Mini Group
Posted 20 March 2014 - 09:30 AM
You'll want some Metro door pockets then. They look almost identical to the Mini ones bit have a speaker enclosure in them. I have a set if you want some. I've fitted a pair of 2 ways in the eyeball vents, I don't run slot of bass through them and use them more like tweeters and let my 6x9's/subwoofers do the hard work. I've used a 6x9 speaker board under the rear seat with Vibe QB69's, they're more of a 6x9 sized subwoofer than conventional 6x9 and give good bass when setup right with a decent amp.
#8 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 20 March 2014 - 05:25 PM
Not necessarily, there are some on ebay for the Mini, however they are £60.
I will be getting some, as the pods under the dashboard frankly just look terrible, even though that is the best positioning with regards to audio.
#9 InstantCustard
InstantCustard
  • 80 posts
Posted 20 March 2014 - 09:53 PM
But the OP said he wanted it to look factory fit, the ones on eBay don't look factory fit.
