Insulation block
6 replies to this topic
#1 AlexM
AlexM
  • 1,302 posts
  • Local Club: NMOC, ECMC
Posted 02 June 2006 - 10:46 AM
Should the insulation block between the throttle body and the inlet manifold on an spi have a paper gasket on each side? One side Or no sides?
#2 pikey7
pikey7
  • 3,824 posts
Posted 02 June 2006 - 10:48 AM
any side that needs sealing. There should be 3 in all. inlet-bracket, bracket-spacer, spacer-carb.
#3 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 02 June 2006 - 10:49 AM
well on my carb i have one on both sides.
It is there to make a good seal so i would say yes have it on both sides, mine is a crab however but i can't see why it would be any different.
#4 AlexM
AlexM
  • 1,302 posts
Posted 02 June 2006 - 10:58 AM
What is the bracket you are referring too? whats a crab?
The reason I ask is that i believe it is causing an vacuum leak.
Do i need to seal it with sealant when i put the gaskets on?
can i use normal gasket paper?
#5 pikey7
pikey7
  • 3,824 posts
Posted 02 June 2006 - 11:02 AM
not sure about your setup, but most of the carbs I've seen have a bracket to hold the outer cables which doubles as a heat shield.
My point was, that you need to have a gasket between all the components. You can use sealer, I know I do for extra security, but strictly speaking its not necessary. Normal gasket paper is fine, but surely you can pick them up precut for pence!?
And last but not least, a crab is an 8 legged animal that walks sideways! :proud: A carb however is a carburettor! :crazy:
#6 AlexM
AlexM
  • 1,302 posts
Posted 02 June 2006 - 11:11 AM
And last but not least, a crab is an 8 legged animal that walks sideways! :proud: A carb however is a carburettor! :angel:
I shall go ahead then!
Is it worth going to buy a precut one when i have some paper at home, also i cannot seem to find the gaskets on any minispares websites, thats why i wondered wether one is even supposed to be there.
about the crab :crazy:
#7 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 02 June 2006 - 03:36 PM
TB, gasket, Insulator, gasket, manifold.
