Suspension Is Bouncing Like Crazy ! Help!
11 replies to this topic
#1 felixy69
felixy69
  • 186 posts
Posted 07 February 2014 - 11:20 AM
So I have replaced my shocks to after market KYB
But the car is still bouncing like crazy over every little bump
What else can I change to adjust the rebound??
Edited by felixy69, 07 February 2014 - 11:32 AM.
#2 racingbob
racingbob
  • 3,061 posts
Posted 07 February 2014 - 11:27 AM
why don't you see if a mates got some spax adjustable to try
maybe from his car there easy enough to take off
#3 Will16
Will16
    Wants a custom member title
  • 1,090 posts
Posted 07 February 2014 - 11:33 AM
What?
#4 felixy69
felixy69
  • 186 posts
Posted 07 February 2014 - 11:37 AM
Nah I just spent the money on shocks...... :(
#5 Craig89
Craig89
  • 600 posts
Posted 07 February 2014 - 01:32 PM
Your rubber cones may have sagged and gone hard therefore no longer being efficient as a spring and you are just bouncing over everything
#6 ado15
ado15
  • 614 posts
Posted 07 February 2014 - 01:36 PM
If the car is sitting low, it will be bouncing off the bump stops. This gives a huge rate change in the front suspension travel and creates unpredictable handling on uneven surfaces. If it is particularly low, get it raised back up and it will handle so much better.
If it hasn't been lowered intentionally, it will be collapsed rubber cones and/or worn knuckle joints. Get them replaced. Don't be tempted to fit hi-lo's to compensate for collapsed cones. You may get the car back up again, but you still have collapsed springs.
#7 felixy69
felixy69
  • 186 posts
Posted 08 February 2014 - 02:00 AM
i have shorten shocks...so now should i change the bump stop to aftermarket ones?
http://www.minisport..._SPDSP450E.html
Edited by felixy69, 08 February 2014 - 02:00 AM.
#8 Carlos W
Carlos W
  • 10,114 posts
Posted 08 February 2014 - 08:44 AM
The car shouldn't be sitting on the bump stops, if it is its too low and may cause a ball joint to fail.
If this happens at speed it'll be quite high on the bad day-ometer!
As suggested above the cones may have collapsed, if this is the case when you replace them it'll be a massive improvement
#9 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 08 February 2014 - 11:09 AM
Apologies if this is a stupid question, but I take it you have driven minis before? I only ask because a woman where I work bought one a few years back (a very nice sky) and complained for a couple of weeks about how the suspension was shot, she had been quoted £1000 to sort it. I took it for a drive and it was a case of 'they are all like that sir'. It drove beautifully. She had been used to modern cars and just couldn't believe the bumpy ride was normal. Heaven knows what the garage was going to do. Obviously if you are used to minis then ignore this post.
#10 ado15
ado15
  • 614 posts
Posted 08 February 2014 - 11:12 AM
I wasn't aware of KYB offering 'shortened shocks'. But I stand to be corrected. Not that the shocks should affect the bump stop requirement.
#11 Cooperman
  • 23,325 posts
Posted 08 February 2014 - 03:42 PM
Set to standard ride height if it is lowered and if you drive on normal roads.
#12 felixy69
felixy69
  • 186 posts
Posted 09 February 2014 - 01:27 AM
i dont think my car is too low .....its just lowered and have 10`wheels ....
i got them from japan.....
