My Speedometer Calibration
Posted 07 February 2014 - 01:19 PM
Josh.
Posted 07 February 2014 - 01:32 PM
The ratio in the 'new' gearbox is unlikely to be 3.44:1 if it's a 1275 Mayfair. To be this model, it would have to be a '90's Mini and they will have had 3.1:1 mainly. But I believe other ratios were also used at this time, including the 2.95:1 which is likely to have been the same in your City E.
The wheels/tyres make no difference. Well, not a difference that is worth worrying about. The rolling radius on all Mini tyres is pretty much the same. Although it's for a different reason, there are some diameters in our article here to demonstrate just how little difference there is:
http://www.dsnclassi...and-clearances/
The speed percentage difference is directly proportional to the diff ratio difference. However, it is also possible that the speedo drive gear ratio might be different.
Given Mini speedo's are not exactly accurate at the best of times, I'd check it against a GPS to get the most accurate idea of the error.
Posted 07 February 2014 - 01:43 PM
I downloaded a speedometer app on my i-phone as my speedo is out by miles - says Im doing 50 when Im actually doing 70. Phone app is pretty acurate tho which surprised me. One day I might sort it out if I can be ar*ed. Rev counter seems all to ******* as well!
Posted 07 February 2014 - 01:45 PM
Interesting. Is this just a GPS speedo?
Posted 07 February 2014 - 01:54 PM
I think it must be - not seen any results of going through bad reception areas.
Posted 07 February 2014 - 02:03 PM
Yes, that's the biggest issue with relying on GPS. But the OP could use it to check speedo inaccuracy assuming there's an app for his phone!
Posted 07 February 2014 - 02:59 PM
Just looked - his age is down as 19 - BOUND to have an new type phone if he's anything like my 19 yr old son!!! As you rightly say Ado15, it could give him a fair idea of his speedo variation.
Posted 07 February 2014 - 04:02 PM
Yes, and if it reads 50 when doing 70, it is seriously illegal and needs the correct drive gears fitted to sort it out. But first the diff ratio needs to be established.
It is worth reminding people, just in case anyone reading this misunderstands, that using GPS as your speedo is not legal, and no-one here is saying that it is. Your speedo is legally required to operate at all times, GPS does not (tunnels, among tall buildings, when deliberately and illegally jammed, which I have actually found on occasion, when Obama turns it off for military operations, etc.) however it is an excellent way of checking that the speedo is correct. I do that regularly in my daily driver. There have been tedious and somewhat acrimonious debates on this subject in the past, and it would be best to not go there again.
Edited by tiger99, 07 February 2014 - 04:02 PM.
Posted 07 February 2014 - 04:07 PM
Posted 07 February 2014 - 04:52 PM
You can either play with the speedo drive gears as tiger99 says, or there are companies that will recalibrate your speedo.
Posted 07 February 2014 - 07:42 PM
Posted 07 February 2014 - 08:00 PM
http://home.comcast....odes/speedo.pdf
It won't fix the odometer though.
