a panels
7 replies to this topic
#1 davexdavexdave
davexdavexdave
  • 650 posts
Posted 02 June 2006 - 01:53 PM
how do i weld a panels on with a mig welder?? is it as simple as it seems or is there some secret method??
#2 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 02 June 2006 - 02:01 PM
yep mig weld them.
i think they were spot welded at the factory. so plug welding would be a good idea i spose.
#3 davexdavexdave
davexdavexdave
  • 650 posts
Posted 02 June 2006 - 02:02 PM
yeah prpbably gonna sound stupid but what does that mean?
#4 miniboo
miniboo
  • 9,327 posts
Posted 02 June 2006 - 02:04 PM
there is a website somewhere explaining about welds etc. the link is in a thread on here somewhere
#5 davexdavexdave
davexdavexdave
  • 650 posts
Posted 02 June 2006 - 02:06 PM
ok cheers.
#6 cooper_shaz
cooper_shaz
  • 1,000 posts
Posted 02 June 2006 - 03:24 PM
for the A panels the top and bottom have a small bead of weld holding them
as for the seam strip plug weld is easy and will allow the seam finish strip to be added easy.
Remove the odl A panel and clean the edge of the wing spotless.
drill holes in the lip of the a panel and clamp the whole thing in place, then with a low wire feed on the mig start to fill the hole in the a panel lip from the middle ie welding to the wing first then filling the hole so it joins to the a panel
you do this for a good weld or you may not joint to the wing properly.
then a quick skim with the grinder to smooth it.
about 6 of them minimum will do
once you have it all in place get some brushable seam sealer and cover the joints and the inner a panel
joins, this is the stuff you see on new car boot joins, makes it waterproof and it is pretty chip resistant so will help keep the rust away in furute.
hope this helps
cheers
Shaz
#7 miniboo
miniboo
  • 9,327 posts
Posted 02 June 2006 - 07:39 PM
found the link finally
http://www.mig-welding.co.uk/
#8 davexdavexdave
davexdavexdave
  • 650 posts
Posted 02 June 2006 - 07:44 PM
thanks cooper shaz helped alot
