Where are you looking for spark and how have you been testing for spark?
The coil will not make a spark until the flow of current through it "stops". Connecting power directly to coil (+) will not make a spark until the engine is turning over such that the points are opening and closing or the electronic module is switching on and off.
As an additional test to what you may have already tried, remove a spark plug and pull the high-tension lead from the center of the distributor cap but leave the plug in the coil. Connect the high-tension lead directly to the spark plug you removed and rest the plug on the cylinder head. Crank the engine over on the starter while looking for spark. If the plug fires, you probably have an issue with the distributor cap or rotor. If it does not fire, the problem is in the low-tension wiring (points somehow shorted to earth, bad condenser, etc).
