Hello all, been a while since ive fitted standard fuel lines to a mini.
Basically im fitting a clubman estate out, so ive got the short pipe from the tank
( http://minispares.co...sic/21A307.aspx )
which will connect with rubber hose to the main fuel line. I need to know what size the fuel line should be, hopefully it will match the minispares tank pipe so i dont need any different dia hose or adaptors.
Jordie
