Pedal Box
Best Answer 087dave , 09 February 2014 - 11:34 PM
Thanks bud Go to the full post
2 replies to this topic
#1 087dave
087dave
  • 952 posts
Posted 09 February 2014 - 08:58 PM
Hi
I am converting a auto 1976 to manual engine to my 76 car
I have taken out the pedal box. I am also fitting
Brake system from a 1991 car so I am changing
The brake pedal as well as a new clutch pedal
What I would like to know is does the clutch pedal have a spring on the pedal box
Tks
#2 tiger99
tiger99
  • 8,584 posts
Posted 09 February 2014 - 10:52 PM
Yes, it is absolutely essential that the clutch pedal on all Minis has a heavy return spring. See here for the part that you require:
http://www.somerford...age=page&id=145
Item 9 is the spring that you require if you have a servo. There is no spring on the brake pedal, an internal spring in the servo providing the same functionality. If you did not have the servo, you would need the dual spring, item 8.
#3 087dave
087dave
  • 952 posts
Posted 09 February 2014 - 11:34 PM   Best Answer
Thanks bud
