Will a HIF 38 from a Austin A40 fit on a Mini 998? Thanks
Hif 38 From A Austin A40 Fit On A Mini 998?
Posted 09 February 2014 - 10:22 PM
Posted 09 February 2014 - 10:45 PM
When you say A40 I assume you mean the late Farina model and not the very different ones from right after WWII. Regardless, the HIF carb would not have been standard on the A40 as they went out of production in the late 1960s if Wikipedia is correct.
While the late A40s used A-series engines, the displacements indicate these were inline engines, not transverse. Therefore, any carb you get off the A40 could be made to work on the Mini but you will need a Mini specific intake manifold, not the manifold from the A40.
Depending on which engine was in the A40 you may have to change the carb needle to get the HIF carb to work with your setup.
Posted 09 February 2014 - 10:52 PM
Edited by Dusky, 09 February 2014 - 10:53 PM.
Posted 09 February 2014 - 11:36 PM
HIF38 is roughly a 1 1/2" carb so should work with correct needle and spring.
Posted 10 February 2014 - 06:58 AM
