Spark Plugs For A High Compression Engine
5 replies to this topic
#1 Steve-O 2014
Steve-O 2014
  • 312 posts
Posted 11 February 2014 - 10:36 AM
Which spark plugs should be used in a 1000cc high compression engine? Would you stick with  'BP6E S' plugs?
It currently has 'B8E S' plugs fitted by the owner but have been told that these are the wrong plugs by the person who set it up for us.
The only thing is I dont know what has exactly been done to the engine... If it has uprated cams etc will it still be ok to use the BP6E S plugs?
#2 racingbob
racingbob
  • 3,061 posts
Posted 11 February 2014 - 10:56 AM
my car has 11.1 and it runs great on ngk bp7es
its 220 on each pot on the compression tester
probably bit high but not a daily car
been on dyno with those plugs
#3 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 11 February 2014 - 02:23 PM
Drive the car and do a plug reading and read the earth electrode as see if its heat path is correct, My 1330 runs 10.2:1 and runs ok on BP6ES
#4 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 11 February 2014 - 02:25 PM
BP6ES will run virtually all A series engines
#5 hamiltonraceengines
hamiltonraceengines
    Starting My Mini Up
  • 2 posts
Posted 11 February 2014 - 08:47 PM
If running a high compression, perhaps run a colder plug to compensate. KernowCooper saying 6'swhicj work well. Try 7's and see what they look like after a good few hundred miles
#6 Steve-O 2014
Steve-O 2014
  • 312 posts
Posted 13 February 2014 - 05:13 PM
Thanks, Switched all for stock grade plugs
