Msa Rules For Sprint Racing
Posted 11 February 2014 - 07:03 PM
I think as a modified mini with a 1380 it will be classed as an A1?
Does that mean you can have a roll cage? (Hope so as I've already got one)
Do the seats and harnesses have to be in date etc?
I will need an external battery cut off, and a few other things..
Is there anything obvious I'm missing?
Posted 11 February 2014 - 07:32 PM
I take it by 'sprint racing' you mean sprints, as in hillclimbs & sprints? If so, you can use a roll cage in any class including completely standard road going classes. Unless they've changed the regs this year - & I hope they haven't but I've not gone through the new Blue Book yet! - seats & belts don't need to be in date (& if you run in series production or mod-prod you only need the drivers seat & harness anyway (not even that for road going series production)) & you don't need an external battery cut off - just the ignition switch clearly marked on-off will do. Your earth lead needs to be coloured yellow. If you have a cage fitted it needs to have the correct size support plates welded in, & if you replace the standard seat with a floor mounted bucket you'll need the correct support plates there too. I don't know what class A1 is to be honest, but depending how modified your MIni is, it will probably be easiest to run in mod prod (section S of the blue book, page 331 of the on line version). If the car is road legal you can run in mod prod without the car being log booked if it's taxed & MOT'd, otherwise you need an MSA scrute to log book it,
As well as the car, don't forget you'll need a minimum National B speed licence,& an in spec crash helmet, fireproof overalls & gloves. There's often debate about whether fireproof boots are needed!
HTH
Keith
It depends what class you are going to run in & what spec your car is.
A1 usually is the road going class. Therefore you can run a pretty basic car, car has to be road going taxed, insured MOT etc.
Roll cage not required ( although good safety aspect). No in date seats required, although Drivers seat must have a head restraint, (MSA are getting hot on seat mountings), normal seat belt acceptable (however most people change to a four point harness). All trim & glass retained, front & rear bulk heads sealed ( fireproofed), external battery cut off not required ( ignition off must be clearly marked).
These are the basics for the Car. You need overalls, helmet & gloves!.
hope this helps.
Posted 11 February 2014 - 07:53 PM
There isn't really anything major to do then..
I'm now confused between modified saloon and modified production..
Edited by mini-geek, 11 February 2014 - 07:57 PM.
Posted 11 February 2014 - 08:40 PM
Even the afore mentioned friendly local scrute was a bit confused by this, & luckily as the Ibiza had fuel injection, he was actually officiating on our first event & said he wouldn't be bothered if we fitted one! He also said that as the Mini was running a Weber he considered that being able to take a pipe off the electric fuel pump will suffice! A friend of mine has been hillclimbing for donkeys years & he's never been picked up on it, & when I posted the question on the Uphill Racers forum no-one that replied had one fitted either!
One other thing to bear in mind is what tyres you're fitting - depending on the class they may have to be in list 1A or 1B.And really confusinglly different clubs can specify different tyres in their event regs....!! We ran list1A Fuldas on the Ibiza.
Edited by keefr22, 11 February 2014 - 08:51 PM.
Posted 11 February 2014 - 09:36 PM
I have A-032R so that puts me in modified production...
Are the rules regarding not needing an MSA logbook etc. the same in the mod production class if you have a taxed and tested car?
If not I can always tyres that comply..
Posted 11 February 2014 - 09:43 PM
If the car is T&T you can run as road legal mod prod & you don't need an MSA logbook (this is what we did with the Ibiza), but I 'think' you then need to use list 1A tyres - I'd need to read the blue book again to remember correctly, but I'm too tired tonight to get my head round that to be honest! But as I said before, some event regs specify different requirements so you 'might' be able to run list 1B tyres in road legal mod prods in those events. All very confusing isn't it...?! Great fun when you get out though & worth all the headaches going through the blue book!
Posted 11 February 2014 - 09:47 PM
Edit.. I will need to run a1 list tyres or I would be in a class that would allow more mods.. Can always buy new tyres..
Edited by mini-geek, 11 February 2014 - 10:20 PM.
Posted 26 March 2014 - 03:59 PM
