Toggle Switch Help
Posted 11 February 2014 - 07:26 PM
1- on continously
2- off
3- on single sweep
But im really struggling to find such a thing. I can find a 3 position "momentary" switch that when released returns back to the centre off position but it does this from both on positions. I only want it to return to the off from one of the on positions if that makes sense?
I know I can achieve a similar function using relays but im trying to keep it as simple as possible.
Anyone know if there is such a switch or am I out of luck?
Posted 11 February 2014 - 10:33 PM
You can get such switches, but not always suitable for use in a car. I think that if your Mini has rocker switches, adding a toggle may be frowned upon by your insurers, as it adds an injiry risk. However, on an old one, which already has toggle switches, one more will not make much difference. Or, of course, if it is in the area between steering wheel and dash, it is well protected against impact with your face or other parts. And, you may be putting it well out of harm's way, so we will assume that the physical installation can be accomplished safely.
Here is one that should do the job, but it will probably not visually match your other switches:
http://www.thetoolbo...CFQ_HtAodpRkAig
Edit: Such a switch is described as on-off-momentary on, so Google will find you more that are similar. You will need at least a 10 amp rating.
Edited by tiger99, 11 February 2014 - 10:36 PM.
Posted 11 February 2014 - 11:32 PM
electric window switches are 3 poss well at least the W&P electric window kit has them......
Posted 12 February 2014 - 07:58 AM
Edited by Dan, 12 February 2014 - 08:03 AM.
Posted 12 February 2014 - 02:09 PM
