Smiths Rev Gauge Not Working
31 replies to this topic
#1 Dusky
Dusky
  • 5,322 posts
Posted 11 February 2014 - 07:49 PM
Hi all,
while i'm waiting for the weather to get dry ( damn rain here)
Im installing my rev counter, so when I get the mini to run I see the revs when running in the new camshaft.
( For the people intrested, mini will stat, was due to being way to lean :P )
The smiths rev gauge has 3 connections :
- '-VE'
- '+VE'
- 'Trigger'
I connected :
 '-VE' to the body
' +VE' to a posetive terminal
'Trigger' to the negative side of the coil.
Now when I crank the engine on starter motor I don't see any revs, is this normal?
Really need to be sure this is connected right etc, dont want to destroy the camshaft :P
grtz!
#2 jpw1275
jpw1275
  • 2,803 posts
Posted 11 February 2014 - 08:09 PM
hi.... do you have the right rev counter for your car, if you have electronic ignition do you have rvc + numbers on the bottom of the face of the gauge, or rvi if you have points?
cheers james
#3 Dusky
Dusky
  • 5,322 posts
Posted 11 February 2014 - 08:47 PM
cheers james
hi, don't reall yknow what you mean :P
Have points on the car by the way :P
this is the back : DSCF3431.jpg
front : newrev1.jpg
Edited by Dusky, 11 February 2014 - 08:48 PM.
#4 Craig89
Craig89
  • 600 posts
Posted 11 February 2014 - 09:21 PM
Pretty much the same as what I have. It is the correct type and your wiring is correct at the tacho end, you might just want to check the +12v to ensure you have it. So your engine is in and everything is wired up and ready to run? What have you not got (air, fuel, spark) to make sure it doesn't start? Just cranking the engine is only low rpm (probably less than 100rpm) so probably won't register.
#5 Dusky
Dusky
  • 5,322 posts
Posted 11 February 2014 - 10:43 PM
got fuel and spark now, it does want to run when pushing the car in gear,so I asjusted idle etc...
Was firing one cylinder ( when he was lean) yesterday, couldnt try today due to weather... All hints are welcome^^
#6 Carlos W
Carlos W
  • 10,115 posts
Posted 11 February 2014 - 10:49 PM
Is the choke mechanism working properly? Battery fully charged?
#7 Dusky
Dusky
  • 5,322 posts
Posted 11 February 2014 - 11:15 PM
Choke fully out( checked at carb) and battery charged+ on a starter..
grtz
#8 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 12 February 2014 - 02:16 AM
You said you have V+ connected to "a positive terminal".  Where?
If you have ballast ignition system this V+ connection cannot be at the coil.  Use a switched terminal on the fuse box instead to supply the tachometer with full system voltage.
#9 Dusky
Dusky
  • 5,322 posts
Posted 12 February 2014 - 06:44 AM
Using the startermotor + atm :P with a switch in between:p
#10 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 12 February 2014 - 01:00 PM
I assume you mean that your car has the pre-engaged starter motor with the piggy-back solenoid and that you have connected the tach's power supply to the starter motor terminal where all the brown wires are located.  Any other terminal on the starter motor is not going to work for you.  If you have an inertia starter motor, connecting the tach power input wire to it won't work at all.
#11 mini 4o
mini 4o
  • 318 posts
  • Local Club: corfu mini's
Posted 12 February 2014 - 01:49 PM
hi this may help..
Attached File  smith gauge 2.doc   74K   33 downloads
#12 Dusky
Dusky
  • 5,322 posts
Posted 12 February 2014 - 05:00 PM
Yep, have that starter motor with the little 'box' attahed ( 91' mini)
And indeed at the terminal with the brown wires..
grtz!
#13 jpw1275
jpw1275
  • 2,803 posts
Posted 12 February 2014 - 07:45 PM
I'm confused..... Lol.... I thought rvc was for electronic ignition and Rvi was for points ignition? If I'm right then your rev counter isn't right for your car if it has points going off the letters on the bottom of the face of your rev counter
Cheers James
Edited by jpw1275, 12 February 2014 - 07:53 PM.
#14 Dusky
Dusky
  • 5,322 posts
Posted 12 February 2014 - 08:46 PM
Cheers James
Yeah, Heard that oo.. but then I read somewhere that both work on points but only RVC on a electronic..
Weard stuff ;p
#15 jpw1275
jpw1275
  • 2,803 posts
Posted 12 February 2014 - 10:21 PM
Aha that clears that up then..:0)
