It's a 3 door 1998 punto s 60, in gold, 61,000 miles on it, very tidy for the year, it's got a tilt and slide sunroof, has had alloy wheels from a later sporting punto fitted (speedo is still spot on with the GPS speedo I use), had a new cambelt and waterpump 2000 miles ago, along with new filters, oil and sparkplugs, brake pads and hoses and a new clutch slave cylinder as the old one was slightly damp around the seal.
It's also had a different instrument cluster installed, so it's now got a temperature gauge ( which also required a different new temperature sensor to be fitted ) and tachometer, still with the original speedo fitted to keep the original mileage. There's absolutely nothing wrong with it, it's very tidy inside, underneath and outside for its age, apart from a cracked headlight. I took it on a 100 mile drive tonight, and apart from it being slower than my cars and the lack of power steering, it was a joy to drive, no knocks bangs or rattles whatsoever. Any ideas how much it's worth? Will be sold with a fresh mot and around 5 months tax. I shall try and get some pictures up tommorow.
Edited by samsfern, 12 February 2014 - 09:43 PM.
