Can adjustable tie bars be adjusted still on the car if jacked up?
Edited by megamini_jb, 13 February 2014 - 01:41 PM.
Posted 13 February 2014 - 01:39 PM
Posted 13 February 2014 - 01:49 PM
Posted 13 February 2014 - 01:53 PM
Edited by megamini_jb, 13 February 2014 - 01:54 PM.
Posted 13 February 2014 - 01:56 PM
Edited by megamini_jb, 13 February 2014 - 01:56 PM.
Posted 13 February 2014 - 01:57 PM
Posted 13 February 2014 - 02:01 PM
That does look a lot of camber. You can get fixed arms with the hole further out to give more negative camber, usually 1.5 or 2 degrees. To get rid of that you would need to swap the arms for standard ones. Can you get a pic of the bottom arm itself?
Posted 13 February 2014 - 02:06 PM
Posted 13 February 2014 - 02:10 PM
Adjustable front tie-bars are designed to use with standard lower arms. They are used to set the caster which should be 2.75 to 3.5 degrees and set to suit the type of use.
Posted 13 February 2014 - 02:21 PM
Posted 13 February 2014 - 02:23 PM
Ok thanks. So I need to get some standard bottom arms?
Posted 13 February 2014 - 02:25 PM
Edited by megamini_jb, 13 February 2014 - 02:26 PM.
Posted 13 February 2014 - 02:26 PM
Alright thanks. Mine must be the fixed neg camber arms then
Posted 13 February 2014 - 04:21 PM
you should post up some pics in the stance thread
the kids will think your cool with that much camber , or is that kool ? I'm too old
