Mini Cooper S Cold Start Problem
4 replies to this topic
#1 njsupplies
njsupplies
    Starting My Mini Up
  • 2 posts
Posted 13 February 2014 - 03:46 PM
I have a problem with my 2007 mini cooper s. on a cold start it has trouble starting, and sometimes when driving it shortly after I put my foot down and it kinda lags slowly then like misfires and then the power comes in
Symptom when I first start the car it starts for a second, then cuts out or chuggs a few times then cuts out it can do it 4-6 times. And sometimes while driving normally it kinda lags wen putting your foot down, then misfires
I believe this may be a common thing, but I am new to mini and this forum, any help would be greatly appreciated
Nikki
#2 creakyjaws5533
creakyjaws5533
    My jaw needs oiling. Where's the WD40??
  • 1,195 posts
Posted 13 February 2014 - 03:51 PM
Might be worth trying a forum for BINIs as this is for classic minis although a few on here maybe able to help you will have more luck on MINI2
#3 petehuws
petehuws
  • 329 posts
Posted 13 February 2014 - 04:32 PM
Yup MINI2 forum will help you out there, or to cut to the chase I swing between old mini & new mini as I have both and it is a common thing with the new mini's right across the range, although since changing the oil & plugs it's not done it since but I know it will be back.  But yes this is well known on the new minis & won't do any harm, mine runs like normal after 20secs or so.
#4 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 13 February 2014 - 04:40 PM
When were your spark plugs last changed?
#5 RedRuby
RedRuby
  • 1,201 posts
  • Local Club: No
Posted 13 February 2014 - 05:21 PM
Could be the crankshaft sensor
