Mini Won't Start, Rapid Clicking
Best Answer bpirie1000 , 15 February 2014 - 08:52 PM
Would suggest a flat battery...... Go to the full post
7 replies to this topic
#1 joshw
joshw
  • 152 posts
Posted 15 February 2014 - 08:21 PM
Hi guys,
Basically coming home from work tonight and every time I braked my radio and indicators would stop working (main beam was unaffected). Parked outside my house tried to start it and all I'm getting is a rapid clicking noise and it won't start.
I'm guessing this could be the battery, solenoid, starter motor or dodgy earth connection. Is there anything else this could be?
Thanks Josh.
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 15 February 2014 - 08:43 PM
You dont mention if yours is a Inertia starter or Pre-Engaged but test is the same for either, just a different setup
Check the battery voltage, may have stopped charging, and the battery is flattened, voltage between13.7-14.3v at 2000rpm then the connections and earths in the boot on the battery - cable and the engine earth. if these prove to be ok then check the feed into the solenoid connections,this should help pinpoint where the fault lies..
#3 minimender
minimender
  • 1,589 posts
  • Local Club: M.M.M.
Posted 15 February 2014 - 08:46 PM
What he said ^^  bad earth prob in boot also check engine earth near brake cylinder, they corrode and you dont notice.
Edited by minimender, 15 February 2014 - 08:49 PM.
#4 bpirie1000
bpirie1000
  • Area Managers
  • 2,356 posts
  • Local Club: Amoc
Posted 15 February 2014 - 08:52 PM   Best Answer
#5 joshw
joshw
  • 152 posts
Posted 15 February 2014 - 09:07 PM
Its pre-engaged (1990), thanks for the help guys I'll report back tomorrow if I get a chance to look at it.
Thanks Josh
#6 joshw
joshw
  • 152 posts
Posted 16 February 2014 - 01:15 PM
All sorted just needed a new battery.
Thanks Josh
#7 Zara
Zara
    BANANAS!
  • 263 posts
  • Local Club: Charnwood Minis
Posted 16 February 2014 - 03:36 PM
was gonna say just sounds like a flat battery! glad you got it sorted :)
#8 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 16 February 2014 - 08:39 PM
Have you checked the charge rate ? always best to so you know its charging fully, lost count of the number of times new batteries have been fitted only for the problem to return in 2/3 days
